Lockdown Audio - A 12v 3way Small Rig Build |
Post Reply | Page <1 121314 |
Jack1991
Registered User Joined: 05 February 2020 Location: Bristol Status: Online Points: 491 |
Couple little changes. Took out all the egg foam stuffing and fitted a few pieces of dacron stuffing to the middle of opposing walls like suggested.
Added foam gasket to the drivers. And changed the old bolts to stainless steel. As the old bolts were just standard black ones and had started to show signs of rust. Will test it out soon and see if it sounds any better like that. Thanks again for your help people.
Lucasdude
Young Croc Joined: 16 March 2013 Location: London Status: Offline Points: 787 |
I remember a friend of mine making a similar cabinet in the early 90s. All we had to go on back then was a "Loudspeaker Design and Construction" by Eminence.... Anyway, he wanted to add a little more flexibility by porting it like yours, but he added a thread to the pipe and capped it so it could be used as sealed or reflex. I can't remember if I ever listened to the difference, but as someone else said you might be better off trying that cab sealed with some eq to the bandpass. I've been meaning to try out what Brazil can bring to the party myself, but it might work for you!
Edited by Lucasdude - 14 May 2022 at 12:03pm |
Jack1991
Yeh id be lost without this forum, i couldnt of done anything just from a book haha. Fairplay for doing so though! I have a dsp the t.racks one seems real good. I guess that one in the link seems similar? This one:
Edited by Jack1991 - 14 May 2022 at 12:47pm |
Lucasdude
I'm only suggesting you consider an automotive solution because its likely to work better on a wider input voltage range like your car amps, can be used standalone, has more outputs and can provide a higher voltage output. Fyi, the same company does a range of chargers/DC psus which I've found quite interesting. A 12v system is great until it runs out of juice and those products can power a lot of amps and charge multiple batteries simultaneously.
Edited by Lucasdude - 14 May 2022 at 12:59pm |
infrasound
Old Croc Joined: 13 May 2011 Location: Brizzle Status: Offline Points: 2276 |
Doesn’t have to be anything special, socks or jumpers work for blocking the port.
Jack1991
Cool cheers man thats good to know for future. Ill have a proper look at them later when home.
Nice thats good ill test it out aswell see how it sounds with the port blocked. Ill see how it looks on winisd too or would the results not match real life?
