Lockdown Experiments |
Page <12345 10> |
doober ![]() Young Croc ![]() ![]() Joined: 03 January 2006 Location: Cornwall UK Status: Offline Points: 1118 |
I made another baffle and fixed the driver and bowl to it, no horn though. Putting the mic just inside a slot gave this (average of 4 measurements)
![]() Just a hint of a dip around 2kHz, so possible not what I'm looking for, but certainly some room for improvement. I made a round bung for the centre of the baffle, with plasticine to fit around 3mm from the driver dust cap. This is the result ![]() Some gains higher up, and still that little dip. Next I added more plasticine to fill up more of the front chamber ![]() This was the result ![]() A loss lower down, small gain higher up. Next I filled up the only space left by adding a ring around the outer edge ![]() This was the result ![]() The response is getting flatter. I think this has taken plasticine technology far enough, so next job is to make something more accurate and hopefully repeatable. |
Blahblahblah
Keen ![]() Young Croc ![]() ![]() Joined: 30 May 2011 Location: Brisbane, Aus Status: Offline Points: 1198 |
would a J7 low end concept be possible here?
bob4 ![]() Old Croc ![]() ![]() Joined: 29 February 2004 Location: Finland/Germany Status: Offline Points: 1795 |
I think it is your slot arrangement. Is this the 6" transducer? At 2khz half of the wavelenght is roughly 8,5 cm. The pairs of slots being parallel obviously doesnt help. Maybe try some radial slots? I mean lines from the center outwards.
Probably. I think the Jericho horns use a band pass arrangement for the low end to get down lower. I don't need so much extension, and I prefer horns ![]() |
Blahblahblah
Yes this is the 6" driver. I see your point and would expect that cancellation if I measure at some distance from the baffle, maybe I should have done a measurement to check that. Distance between the slots is 58mm on the inner edge, 89mm on the outer edge. I'm not sure if the photos show the exact arrangement, each slot feeds an individual mini horn, these horns bend around so the mouths end up in a vertical line. The reason I chose the slot positions is to make the bends as smooth and simple as possible, with the bend being in the shorter side of the horn and with minimal twisting. It was also to keep the mini horns as short as possible, as adding length lowers the flare rate which may reduce the loading at higher frequencies. I'm not sure how I could use radial slots with this arrangement. |
Blahblahblah
I see, i forgot about that aspect of your design
J7's a bit different....
![]() ![]() ![]() you could possibly close out the mf/hf horn this way. |
FOO ![]() Young Croc ![]() ![]() Joined: 23 December 2018 Location: Denmark Status: Offline Points: 758 |
Emmy drivers in a Danley box.. didnt expect that.
csg ![]() Old Croc ![]() Joined: 17 September 2007 Location: bedford Status: Offline Points: 6086 |
Look like BMS oem’s to me. Either that or some shameless copying is going on
citizensc ![]() Young Croc ![]() ![]() Joined: 16 October 2015 Location: Perth,Australia Status: Offline Points: 532 |
Looks like a N151M, i'm surprised they are not BMS 4550. It may be a weight thing, those N151M are light, by my maths its a 14.5kg weight saving when compared to the 4550.
Timebomb ![]() Old Croc ![]() ![]() Joined: 11 October 2004 Location: Lancaster Status: Offline Points: 2707 |
I tested the N151M-8, its very close to BMS 4540nd in sound and response, im not 100% but i think Eminence may get the diaphragms from BMS, they sound very very similar.
Its very easy to identify the Emmy logo. No doubt there. And i agree on the N151M.
But hey.... EAW and many other does use Emmy speakers in some designs. As i can remember, both DCS2 and LA400 are using Emmy 12". And they can make some fine noise :)
Page <12345 10> |
