  New Posts New Posts RSS Feed - Looking for a bigger amp than a 2020 amp
tcourtneyvincent View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tcourtneyvincent Quote  Post ReplyReply Direct Link To This Post Topic: Looking for a bigger amp than a 2020 amp
    Posted: 04 December 2012 at 12:57pm
Im sure that 20w a side is not enough power for what i want, so im looking for a bigger amp which still idles at low power, is there such a thing?
Thanks
Saturnus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Saturnus Quote  Post ReplyReply Direct Link To This Post Posted: 04 December 2012 at 1:22pm
Do you know for sure? It doesn't cost much buy a low cost TA2020 amp to test it.
Idle consumption invariably goes up and low power level efficiency inavariably drops with increases potential output.
If you're searching for low cost then there's Sure amps. They have many different models. Generally needs modding if high quality output is needed. For a slightly higher price and much better quality there's the classDaudio amps which are especially good at running subs.
amlu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote amlu Quote  Post ReplyReply Direct Link To This Post Posted: 05 December 2012 at 1:56pm
what will you recommend? i`m using old models of sure 2x100watt the moment, got 24v supply available...
boofarino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boofarino Quote  Post ReplyReply Direct Link To This Post Posted: 06 December 2012 at 12:02pm
I am in a similar situation, trying to decide between the TA2020 and Sure TSA5613.  Also think ill need the power of the Sure but not sure if ill get enough battery life out of it on 24v7ah.
