  New Posts New Posts RSS Feed - Looking for a skilled Hornresp user - RCF L15P/06C
dcibel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dcibel Quote  Post ReplyReply Direct Link To This Post Topic: Looking for a skilled Hornresp user - RCF L15P/06C
    Posted: 20 October 2015 at 3:48am
Hi all,
I have a pair of ancient speakers that I would like to put to good use. They are RCF L15P/06C. I haven't found much info about them online, just a few posts. They seem to be well liked, and one post suggested that they would work well in a "Staiper Microscoop". These speakers have a exteremely low Qts making them difficult to use in a "normal" sealed or ported cab, so I am open to other suggestions on what to do with them.
I am not new to acoustic design, however I don't really have any horn experience. Is there someone experienced with Hornresp that can run a simulation of this driver in a Microscoop? Below is the cabinet design and a link to my measured T/S parameters.
https://drive.google.com/file/d/0B-GpgK57lLMNZGxGdWVUaTMyLVE/view?usp=sharing
Edited by dcibel - 21 October 2015 at 4:49pm
JR.junior View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR.junior Quote  Post ReplyReply Direct Link To This Post Posted: 20 October 2015 at 8:35am
will do it in time.
Edited by JR.junior - 20 October 2015 at 8:48am
Post Options Post Options   Thanks (0) Thanks(0)   Quote dcibel Quote  Post ReplyReply Direct Link To This Post Posted: 20 October 2015 at 2:28pm
Thank you.
I am also open to suggestions, if there is something more suited to use with these drivers, like a BFM Tuba 30 or somehing like that.
all bass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote all bass Quote  Post ReplyReply Direct Link To This Post Posted: 21 October 2015 at 6:38am
Originally posted by dcibel dcibel wrote:
Thank you.
There is no 15" Tuba. Might fit a Titan48.
b grade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote b grade Quote  Post ReplyReply Direct Link To This Post Posted: 21 October 2015 at 2:25pm
Tuba 60 can be made for a Lab15 apparently. Its the "small" (LOL) version, as opposed to the full version with dual lab 12s.
fatfreddiescat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fatfreddiescat Quote  Post ReplyReply Direct Link To This Post Posted: 21 October 2015 at 3:47pm
Try putting the model number of the drivers in your thread title, you just may catch some ones attention
Teunos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Teunos Quote  Post ReplyReply Direct Link To This Post Posted: 21 October 2015 at 4:25pm
This is a model of it i once did quite some time ago. Modeled as a tapped horn with the taper at the center of the panel where the speaker attaches. Think its pretty accurate though. Put in your own parameters to run the simulation.
Best regards,
Teun.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dcibel Quote  Post ReplyReply Direct Link To This Post Posted: 21 October 2015 at 4:50pm
Done
Thanks, I'll have a look at this later today!
turbo7 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote turbo7 Quote  Post ReplyReply Direct Link To This Post Posted: 21 October 2015 at 9:43pm
i would help but find no parameters ! High overall damping is good, but what about x-max f. ex !
Post Options Post Options   Thanks (0) Thanks(0)   Quote dcibel Quote  Post ReplyReply Direct Link To This Post Posted: 21 October 2015 at 11:23pm
Parameters were linked in my first post. Here they are again:
Xmax is unknown, estimate between 4-5mm.
Edited by dcibel - 21 October 2015 at 11:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote dcibel Quote  Post ReplyReply Direct Link To This Post Posted: 22 October 2015 at 7:59pm
How do I get "Fr" and "Tal" to show up for a Tapped horn? Once I set the driver arrangement to Tapped Horn, these values change to "Ap" and "Lpt".
I also found this thread with some different values for this cab, which I'll try out as well once I can figure out this Hornresp program, just for comparison sake.
http://forum.speakerplans.com/staiper-micro-scoop-on-winisd-hornrsp_topic52339.html
