  New Posts New Posts RSS Feed - Looking for a small 60x 40 horn for a 1" comp
luthier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote luthier Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2019 at 7:03pm
Note: the chamber would mount like that on the back of a fibreglass horn.
snowflake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2019 at 7:30pm
would a different driver that is happy in a much larger chamber make things simpler?
smitske96 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2019 at 7:53pm
You could also make it dual 15 with v loading.
Post Options Post Options   Thanks (0) Thanks(0)   Quote luthier Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2019 at 10:43pm
I agree it could indeed be easier, but where's the fun in that? Wink
If I make a back bowl that mounts onto the driver itself I could always remove it and use another, perhaps better suited driver further down the line in prototyping?
Post Options Post Options   Thanks (0) Thanks(0)   Quote luthier Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2019 at 10:48pm
I did consider it, but it would mean getting another more powerful amplifier and potentially making a larger cabinet.
I also just like the challenge of the horn section, I'm learning loads. If I wanted simple I'd have done the smart thing and just made some reflex boxes with good quality drivers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote luthier Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2019 at 10:54pm
Here's a slightly updated rendering.
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2019 at 10:00pm
Originally posted by luthier luthier wrote:
Both of those Faital horns sound bloody lovely with one of their ketone polymer drivers on the end of it too.
I had a look at the hf108, the frequency response graph looked phenomenal. It was like a lake!
Here's some real porno
https://www.audioxpress.com/article/Test-Bench-Faital-Pro-s-HF108-HF108R-compression-drivers-coupled-with-LTH102-60-50-horn
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2019 at 11:05pm
Those are just BMS copies :-)
Timebomb View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Timebomb Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2019 at 9:49am
The HF108 sounded smoother than the 4540nd when i tested it, less harsh and aggressive, and much flatter response on my horn.  BMS had slightly better sensitivity overall, but suspect real world power handling will be lower on the BMS, both say 60W but 38mm coil vs 44mm on the Faital.    I wouldnt say all annular diaphragm drivers are copys of BMS, its quite a different driver Marjan :)
Celestion CDX1-1730 / 1731 with a bit of EQ was just as nice as the Faital, i would recommend that one but the HF108 is a nice driver.
gen0me View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gen0me Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2019 at 10:31am
Originally posted by <img src=smileys/smiley36.gif border=0 alt=LOL title=LOL />MarjanM LOLMarjanM wrote:
Originally posted by https://faitalpro.com/en/products/HF_Drivers/product_details/index.php?id=502010170 https://faitalpro.com/en/products/HF_Drivers/product_details/index.php?id=502010170 wrote:
Diaphragm ShapeDome
How is the LTH102 on listening? Is it rolling off highs off axis or not?
Edited by gen0me - 22 January 2019 at 10:34am
Mixes: https://www.mixcloud.com/gen-ome/
bass*en*mass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2019 at 8:27pm
plenty of single annular HF comps available soon i guess, get out your wallets and compare for yourselfes gents? :)
btw. luthier, i would personally not spend a single min. spending my time craming a complicated flh into that design when a simple 2x12 V loaded reflex would be just as capable, more forgiving and more or less just as compromising within given volume..
Edited by bass*en*mass - 22 January 2019 at 8:31pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote luthier Quote  Post ReplyReply Direct Link To This Post Posted: 23 January 2019 at 9:08am
It has definitely been intresting reading the responses about the CDs, if I do go for any of the above I'll make sure to post.
