p audio SN 15MB alternatives |
Post Reply | Page 12> |
teeth
Young Croc Joined: 05 July 2021 Status: Offline Points: 561 |
Posted: 20 September 2022 at 10:50am |
i've just acquired a pair of lovely X15's unfortunately one SN 15MB is blown (?) no sound at all. i've no idea how to diagnose this let alone fix it, so i guess i will have replace... i see the SN15MB is OOP, on the offchance anyone knows of anyone selling that would be ace. failing that, i guess i'll have to get a pair of replacement drivers, has anyone got any recommendations? i have some fane sov's kicking about, hardly a viable replacement but...? EDIT: have some options here it seems
Edited by teeth - 05 November 2022 at 12:27pm |
Earplug
I may have one, but postage could be expensive. I'll PM you later. Edited by Earplug - 20 September 2022 at 1:42pm |
teeth
thanks earplug, i'll await your message :) |
Earplug
Ok, PM sent. |
teeth
i'm going to try them with a pair of fane 600LF all i have til the p-audio from earplug arrives will report back :)
teeth
plugged the TSPs in to that site and got a few options back
cravings
there was always a bit of ambiguity / weirdness with published specs for p-audio stuff, just saying..
teeth
i'm not surprised you said that tbh the specs i saw aren't quite there... 3.5mm xmax? here's a bit of info i found P-Audio SN 15MB 300w old model: Thiele-Small Parameters P-Audio 15BM-300B 15" 300W New model: Re.....................................................................................5.7 i think i'll have to make some informed decisions with regards to what driver options to explore tbh |
smitske96
Young Croc Joined: 16 February 2016 Location: The Netherlands Status: Offline Points: 1085 |
The xmax of P-audio drivers is calculated by the conservative way like BMS does: (VC winding height - Gap height) / 2
The biggest P-audio problem is big factory tolerances and the ever changing spec sheets for drivers. So even if you plug these TS-paramters in, chances are big the eventual drivers does not come close. Do you already have those drivers? |
APW
Young Croc Joined: 13 November 2012 Location: Kent, UK Status: Offline Points: 1173 |
Why not get them reconed? Drop Wembley and/or RMJ a line. |
teeth
yes smitske96 - i have one and on that needs reconing thanks APW - i'll see if they can recone, probably the best option. hope they can get kits. i do wonder if there is a driver out there that's suitable for the use case, and if so, i'd like to find it. currently there are no recommeneded drivers for the plan which is a shame, they're a cool design. i'd like to find something that could ammend the plan so people can build them again. |
teeth
looking at the fane 15 300 TC it's a fullrange 15" so could be roll the HPF and LPF up a bit if you were using midbass such as kicks etc and would take some strain off the comp driver. mine is x-d over quite low |
