  New Posts New Posts RSS Feed - p audio SN 15MB alternatives
teeth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth Quote  Post ReplyReply Direct Link To This Post Topic: p audio SN 15MB alternatives
    Posted: 20 September 2022 at 10:50am
i've just acquired a pair of lovely X15's
unfortunately one SN 15MB is blown (?) no sound at all.
i've no idea how to diagnose this let alone fix it, so i guess i will have replace...
i see the SN15MB is OOP, on the offchance anyone knows of anyone selling that would be ace.
failing that, i guess i'll have to get a pair of replacement drivers, has anyone got any recommendations? i have some fane sov's kicking about, hardly a viable replacement but...?
EDIT:
have some options here it seems
Edited by teeth - 05 November 2022 at 12:27pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 20 September 2022 at 1:41pm
I may have one, but postage could be expensive. I'll PM you later.   Smile
Edited by Earplug - 20 September 2022 at 1:42pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth Quote  Post ReplyReply Direct Link To This Post Posted: 21 September 2022 at 9:43am
thanks earplug, i'll await your message :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 21 September 2022 at 1:54pm
Ok, PM sent.  Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth Quote  Post ReplyReply Direct Link To This Post Posted: 30 September 2022 at 11:20am
i'm going to try them with a pair of fane 600LF
all i have til the p-audio from earplug arrives
will report back :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth Quote  Post ReplyReply Direct Link To This Post Posted: 05 November 2022 at 12:30pm
plugged the TSPs in to that site and got a few options back
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 05 November 2022 at 12:57pm
there was always a bit of ambiguity / weirdness with published specs for p-audio stuff, just saying..
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth Quote  Post ReplyReply Direct Link To This Post Posted: 06 November 2022 at 10:59am
i'm not surprised you said that tbh the specs i saw aren't quite there... 3.5mm xmax?
here's a bit of info i found
P-Audio SN 15MB 300w old model:
Thiele-Small Parameters
Resonant Fequency (fs) 47 Hz
Impedance (Re) 5.5 ohms
Coil Inductance (le) 0.85
Electromagnetic Q (Qes) 0.31
Mechanical Q (Qms) 8.31
Total Q (Qts) 0.30
Compliance Eqiv. Volume 176 liters
Mechanical Compliance of Suspension (Cms) 151 uM/N
BL Product (BL) 19.70 T-M
Diaphragm Mass incl. Airload (Mms) 75.7 grams
Equivalent Resistance of Mech. Suspension Loss (Rms) N/A
Efficiency Bandwidth Product (EBP) 151
Voice Coil Overhang (Xmax) 3.5mm
Surface Area of Cone (Sd) 907cm2
P-Audio 15BM-300B 15" 300W New model:
Re.....................................................................................5.7
Fs...................................................................................48hz
Mms................................................................92.19 grams
Mmd................................................................77.81
Qms..................................................................................5.39
Qes...................................................................................0.43
Qts....................................................................................0.40
Vas..................................................................123.35l
BI...............................................................................19.19
Cms.......................................................................1.2e-04 m/n
Rms.........................................................................5.10 ns/m
Le (at 1kHz)................................................................0.44 mh
i think i'll have to make some informed decisions with regards to what driver options to explore tbh
smitske96 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 06 November 2022 at 11:47am
The xmax of P-audio drivers is calculated by the conservative way like BMS does: (VC winding height - Gap height) / 2
The biggest P-audio problem is big factory tolerances and the ever changing spec sheets for drivers. So even if you plug these TS-paramters in, chances are big the eventual drivers does not come close.
Do you already have those drivers?
APW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote APW Quote  Post ReplyReply Direct Link To This Post Posted: 06 November 2022 at 12:30pm
Why not get them reconed?
Drop Wembley and/or RMJ a line.
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth Quote  Post ReplyReply Direct Link To This Post Posted: 06 November 2022 at 2:12pm
yes smitske96 - i have one and on that needs reconing
thanks APW - i'll see if they can recone, probably the best option. hope they can get kits.
i do wonder if there is a driver out there that's suitable for the use case, and if so, i'd like to find it.
currently there are no recommeneded drivers for the plan which is a shame, they're a cool design. i'd like to find something that could ammend the plan so people can build them again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth Quote  Post ReplyReply Direct Link To This Post Posted: 06 November 2022 at 4:43pm
looking at the fane 15 300 TC
it's a fullrange 15" so could be roll the HPF and LPF up a bit if you were using midbass such as kicks etc and would take some strain off the comp driver. mine is x-d over quite low
This page was generated in 0.090 seconds.
