  New Posts New Posts RSS Feed - Loud & powerful15" drivers for single bass reflex
djrobs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djrobs Quote  Post ReplyReply Direct Link To This Post Topic: Loud & powerful15" drivers for single bass reflex
    Posted: 11 July 2018 at 7:50pm
I want to building 4 15" BR boxes,, punchy and crazy bass and so loud its possible. Its for all kind of partys weddings, student partys, club partys etc the sound qualite dosent need to be be hifi just crazy loud. What drivers do you recommend and do you have a design or blue prints for it?
Thanks for a great forum 👌🏻
Edited by djrobs - 11 July 2018 at 8:53pm
Regards Rob
djeddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djeddie Quote  Post ReplyReply Direct Link To This Post Posted: 11 July 2018 at 9:48pm
What's your budget? And why 15"?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 11 July 2018 at 10:07pm
Oberton
JonB67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JonB67 Quote  Post ReplyReply Direct Link To This Post Posted: 11 July 2018 at 10:19pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote JonB67 Quote  Post ReplyReply Direct Link To This Post Posted: 11 July 2018 at 10:21pm
if loud is the key thing, why bass reflex?
nickyburnell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 11 July 2018 at 10:25pm
15tbx100
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 11 July 2018 at 11:05pm
Old B&C Sub15 design loaded with Beyma 15G400.  Works for me....
Post Options Post Options   Thanks (0) Thanks(0)   Quote djrobs Quote  Post ReplyReply Direct Link To This Post Posted: 12 July 2018 at 5:19am
easy to build. What do you recommend of not BR?
Edited by djrobs - 12 July 2018 at 5:21am
Regards Rob
Post Options Post Options   Thanks (0) Thanks(0)   Quote djrobs Quote  Post ReplyReply Direct Link To This Post Posted: 12 July 2018 at 5:54am
Regards Rob
Post Options Post Options   Thanks (0) Thanks(0)   Quote djrobs Quote  Post ReplyReply Direct Link To This Post Posted: 12 July 2018 at 6:11am
400€
Regards Rob
Post Options Post Options   Thanks (0) Thanks(0)   Quote djrobs Quote  Post ReplyReply Direct Link To This Post Posted: 12 July 2018 at 6:12am
400€
The size and easy to transport
Regards Rob
Post Options Post Options   Thanks (0) Thanks(0)   Quote JonB67 Quote  Post ReplyReply Direct Link To This Post Posted: 12 July 2018 at 7:59am
If this question is why not recommend br, the answer is if you want max spl for its size then you'll get more out of a tapped horn than a br and that's what you said you wanted.
Personally I'd build double 15 bass reflex for the flexibility,  but that's for my needs not yours possibly. Also you then need more amp power and it'll double your budget for drivers.
I have bms 15n630  in bass reflex and they go pretty loud. How loud is loud anyway?
If you want to build bass reflex take a look at the p audio e15 600s. Good value if you're on a tight budget as you are.
What amp do you have to run them?
