Loud & powerful15" drivers for single bass reflex |
Page 123> |
djrobs ![]() Registered User ![]() Joined: 19 July 2016 Status: Offline Points: 31 |
![]() ![]() ![]() ![]() ![]() Posted: 11 July 2018 at 7:50pm |
Edited by djrobs - 11 July 2018 at 8:53pm |
Regards Rob
djeddie ![]() Old Croc ![]() ![]() Joined: 26 April 2004 Location: Bristol Status: Offline Points: 4107 |
What's your budget? And why 15"?
Dub Specialist Sound ![]() Old Croc ![]() Joined: 15 November 2013 Location: Smethwick Status: Offline Points: 4873 |
Oberton
JonB67 ![]() Young Croc ![]() Joined: 22 April 2016 Location: UK Status: Offline Points: 1363 |
if loud is the key thing, why bass reflex?
nickyburnell ![]() Old Croc ![]() Joined: 06 February 2005 Status: Offline Points: 4410 |
15tbx100
ceharden ![]() The 10,000 Points Club ![]() ![]() Joined: 05 June 2005 Location: Southampton Status: Offline Points: 11676 |
Old B&C Sub15 design loaded with Beyma 15G400. Works for me....
easy to build. What do you recommend of not BR?
Edited by djrobs - 12 July 2018 at 5:21am |
Regards Rob
Regards Rob
400€
Regards Rob
400€
The size and easy to transport
Regards Rob
If this question is why not recommend br, the answer is if you want max spl for its size then you'll get more out of a tapped horn than a br and that's what you said you wanted. Personally I'd build double 15 bass reflex for the flexibility, but that's for my needs not yours possibly. Also you then need more amp power and it'll double your budget for drivers. I have bms 15n630 in bass reflex and they go pretty loud. How loud is loud anyway? If you want to build bass reflex take a look at the p audio e15 600s. Good value if you're on a tight budget as you are. What amp do you have to run them? |
Page 123> |
