  New Posts New Posts RSS Feed - low cost amp for 1850 Void loaded?
PirateAlien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PirateAlien Quote  Post ReplyReply Direct Link To This Post Topic: low cost amp for 1850 Void loaded?
    Posted: 29 April 2015 at 11:40am
Hi everybody! Smile
I have a little absurd question but I need a more profesional opinion..in this moment I'm building 2x1850's (for the moment... in the future will be 8 or more..) with the void v18, and in the future i want to take some good amp like crown xli3500 or infinite8.. or why not a labgruppen 10.000! LOL ,,
the dreams are free,, But for the moment my budget is limited and I only can buy some lowcost amp for the nexts parties and with time,, go for some other better amps.
Then, I look many times the T.amp TSA 4-1300, I have other thomann amps and run cool.. I read many forums, posts, reviews, etc.. I found a lot of info about, but finaly I need a more especific and serious opinion,,
Will run nice the T.amp 4-1300 with 4x1850's void loaded???
It's realy necesary a high quality amp & expensive for a non profesional soundsistem begining?
I will valorate any proposals and other ideas!
Thanks!
Edited by PirateAlien - 29 April 2015 at 11:58am
THECANDLEMAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote THECANDLEMAN Quote  Post ReplyReply Direct Link To This Post Posted: 29 April 2015 at 1:01pm
4 channel amps in general are designed to run mid or monitors
a few big brand 10k 4 channels can do bass but in general its not a good choice
Prob look at Proline 3000.
Youll be able to run 4 of it no problem
You get the same Thomann support and down the line buying another to go up to running 8 is simple
If you have a bit more money then look at the newer 2 channel amps from SAE that some of the forum members sell (They are £650 ish for the 2 channel youd need)
Motion Systems - Void Airmotion, Airten & Stasys 218 With Powersoft DSP
Post Options Post Options   Thanks (0) Thanks(0)   Quote PirateAlien Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2015 at 8:27pm
Yep,, look's too nice for be real. :')
I discarted the tsa 4-1300 and I'm looking the Proline3000 also many times but I can't use them with 4 subs! It's only for 2.. and if I need to take 4 of this is a lot of weight and money.. for this price I can look maybe better for other amps like crown xli 3500 or the Xls 2500 (digital) also a crest cpx2600 could be a nice choice! better then PROLINE3000?
What u think about american dj amps? are realy bad amps or have a good products? because a friend have some amps and sounds good..I found the American dj XLT2000, anyone know if this amps runs well and if it's analog?
Edited by PirateAlien - 23 May 2015 at 8:28pm
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2015 at 9:14pm
i recon the proline 3000 would probably walk over the other options you just listed tbh, its not quite enough to give four v18s a proper full on pasting but its not that short on power tbh id happily use a proline 3k to run 2 v18 per side tbh if thats not enough juice id be more looking into more bins rather than more power per bin tbh
horn loaded for her pleasure
jammin75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jammin75 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2015 at 9:23pm
i would go with the proline if you can afford it dont bother with the rest or you could see if you can find second hand decent amp plenty of them out there on 4 ohm bridge would easily power them Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2015 at 10:24pm
tbh the proline 3000 has actualy been benched at around 1800w per  channel into 4ohm [i think i might be wrong here but im fairly certain im correct] , now im not saying this is enough to give them a proper run, but what i am saying is that me personaly would only want about say 20/25% more power in my ideal world, for the moment [remember that 20/25% more power is only going to be 1decibel] under powering only does damage to drivers when the amp is being thrashed, the proline should actualy be ok to run 4 v18 like i said if you desperately need that extra 1db id rather gain it by using 6 bins instead of 4 rather than by putting the extra 20% power in
Post Options Post Options   Thanks (0) Thanks(0)   Quote PirateAlien Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2015 at 12:06am
PROLINE3000: estéreo, 8 Ω: 2 × 1100 W estéreo, 4 Ω: 2 × 1500 W estéreo, 2 Ω: 2 × 1800 W puenteado, 8 Ω: 3000 W puenteado, 4 Ω: 3600 W paralelo, 2 Ω: 3000 W
It's not enough for conect 2 bins per side.. maybe 3? it's posible to conect 3 bins with 1 proline? what is the Ohms resultant if the void's are at 8ohms...?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PirateAlien Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2015 at 11:04am
I use the post to share with u the project who i'm doing of 1850 horns! thanks to all for you're opinions!
[/URL]
[/URL]
Edited by PirateAlien - 28 May 2015 at 1:47pm
corell View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote corell Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2015 at 11:27am
Proline 3000:
Hersteller: 2x 1100 Watt an 8 Ohm
Messung: Sinus 2x 1250W/8Ohm, 12db Crest 2x 1550W/8Ohm, Impuls 80Hz 2x 1390W/8Ohm
Hersteller: 2x 1500 Watt an 4 Ohm
Messung: Sinus 2x 2100W/4Ohm, 12db Crest 2x 2200W/4Ohm, Impuls 80Hz 2x 2020W/4Ohm
Hersteller: 2x 1800 Watt an 2 Ohm
Messung: Sinus 2x 2300W/2Ohm, 12db Crest 2x 3000W/2Ohm, Impuls 80Hz 2x 2874W/2Ohm
Thomann TSA 4-1300
Last _ | 1kHz _| 60Hz_ | 1% THD 1kHz (nur 1 Kanal gemessen)
4 Ohm | 3660W | 2794W | 2047W
8 Ohm | 2160W | 1624W | 1235W
Gemessen mit Burst-Signal.
Nach 10ms (jeweils folgend) ohne Berücksichtigung des Klirr: 3192W @4x4 Ohm @ 1kHz
danach stetig abfallend bis 20ms: 2304W @4x4 Ohm @ 1kHz
Innerhalb der ersten 33ms: 2025W @4x4 Ohm @ 60Hz
in den letzten 33ms von 100ms: 1521W @4x4 Ohm @ 60Hz
Post Options Post Options   Thanks (0) Thanks(0)   Quote PirateAlien Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2015 at 1:38pm
Mm cool info but I don't understand well,, finaly you mean who is good to use 2000w @ 4ohm for chanel and the amp have the enought power? at least at the first ms no? :S
jacethebase View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jacethebase Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2015 at 1:42pm
The thought of using a Crown XLS...... again makes me sad :( Truly horrible sounding amps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PirateAlien Quote  Post ReplyReply Direct Link To This Post Posted: 09 September 2015 at 6:22pm
HI everybody! Finaly I have been a good boy Embarrassed and I take a Proline 3000,,, nice choice,, if not for the weight.. uff! I need to take another rack better.. hehe
But now I have a problem to know exactly what is the limitation I need to use! It's very important for me to know the best configuration of them! I have a digital crossovers, and I like to know if there are someone who know how i can calucate well! any help will be apreciated! thanksss!!
Edited by PirateAlien - 09 September 2015 at 6:23pm
