  New Posts New Posts RSS Feed - MA215 Subs
MA215 Subs
AlmostSalty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AlmostSalty Quote  Post ReplyReply Direct Link To This Post Posted: 30 October 2013 at 11:15am
Look at those ladders going up to the stacks! When have you last seen a ladder for a sound?
Allright somebody most have heard ma215's and wsx together?? they fit all the requirments, are they great? Pretty large mouth and a quite flat response i stacks of 4.
TONY.A.S.S. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TONY.A.S.S. Quote  Post ReplyReply Direct Link To This Post Posted: 30 October 2013 at 11:23am
I never see any problems with putting most cabs with most others, it's only a question of coherence, which can be sorted with most LMS's
Robbo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robbo Quote  Post ReplyReply Direct Link To This Post Posted: 30 October 2013 at 1:21pm
MA215s and WSX are cabinets from different eras of touring and install sound reinforcement so it is very doubtful that they have ever been used together--as Tony says, you could line them up with a decent 8 output LMS anyway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AlmostSalty Quote  Post ReplyReply Direct Link To This Post Posted: 30 October 2013 at 1:55pm
Sure, sure.. Im just looking for more than a good bin to line up with the martins, im more after the magic touch, the holy grail of the MA215mk11 kick bin. Not doubting that they wouldnt sound great together, but i know there must be some one/ones on here that has tried and found a great sub to match the martins.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TONY.A.S.S. Quote  Post ReplyReply Direct Link To This Post Posted: 30 October 2013 at 4:38pm
For reasons that Robbo mentioned, you might not get any answers. Back in the days when there were buckets loads of these about, these cabs were the low end, with nothing underneath them, and because larger PA companies used them, they were using more than one per side, so low end would never have been an issue.  Nowadays, when people get these cabs they tend to use them in the way it was intended.
The only subs I've ever seen underneath these cabs in a "Sound System" have been 18" Scoop Bins.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AlmostSalty Quote  Post ReplyReply Direct Link To This Post Posted: 30 October 2013 at 7:03pm
Hmm i see your point! Guess i will have to go and try something out and see if its works.. I got quite hooked on the WSX today but theres still quite some time before my sporadic mind has to make a choice. Just need to find some more subs for hear..
Any favored horn loaded subs??
Right now there running with 4 hog scoops underneath, sounds fantastic for roots! The punch from the martins joins quite nicely with the hogs punch. Now we want to build something a bit more tight and for a wider set of uses...
Peace & Love
