macro-tech vs micro-tech |
Post Reply | Page <1 2345> |
Author | |||
APW
LOL.... They have a precise specification that they MUST comply with, it’s called BS1362 and gives the exact conditions as to when and how the fuse will break... trouble is so many are Chinese fakes that don't comply. |
EmPro
Young Croc Joined: 26 June 2020 Status: Offline Points: 766 |
yes,indeed....way to many fakes around.... and to be honest...nobody test the damn fuses but we should
Edited by EmPro - 27 June 2022 at 2:48pm |
EmPro Audio
APW
What curve is the MCB? Edited by APW - 27 June 2022 at 2:52pm |
EmPro
Type B mate.
EmPro Audio
In the States, the majority does not take in account there are other loads on the breaker consuming current prior to what they are planning to use. So the chances of having all the amperage stated on the breaker for the device the person is about to use at their disposal is a guessing game when asked. We (Electricians) always take in account the overall load passing through the breaker using a clamp meter to monitor the true current consumption.
Best Regards, |
EmPro
In the states: 120v and plenty amps for the rated powers.....if you look in the MT-s data,the 120v versions are little more powerfull on the output then 240v versions of the same model....it shouldn't be like that..but it is,so we need to understand that MT-s are current amplifiers and they need loads of amps to perform,this is the only thing MT-s ask for and you are trouble free for life MT-s never let me down so all the respect for that
EmPro Audio
levyte357-
We should also note, many of the modern day joker amplifiers, with illustrious power ratings measured at 1khz, do not provide truthful max power consumption figures. Unlike Macrotechs, Crest Pro '01 series, EV P3000. Which also make it quite easy to choose a proper sub amplifier. Macrotech docs, even specify the PSU efficiency, so you know well in advance, if you intend to get full power output at 40hz, ensure you have manly mains input !!
EmPro
Indeed mate,the specs of todays junks are just to make people confused,the ratings now in terms of power are pushed to maximum because people like to see big numbers....if you try to sell today 2x500w rms power amp 20hz-20khz nobody will buy it....but if you rate same amplifier at 2x2000w rms (just for 0.3us) people will buy it because 4000w of power in a frequency you might never use and a power you never gonna have it sounds better then 2x500w and if you are not happy with results...you might need a stronger one....that's why today the smallest events have 20.000w of power (on paper) to cover 100 ppl
Edited by EmPro - 28 June 2022 at 2:17pm |
EmPro Audio
kedwardsleisure
the old HH (and Citronic PPX for that matter) were made before MCB boards were widely in use in the UK and the soft start where fitted is minimal. SOme of these vintage amps were known for blown (either open or short) mains switches for a similar reason. Domestic type B breakers do not like these old amps due to the inrush, an industrial type C is usually ok.
But an MA5000 has full triac-controlled soft start and is very kind to the supply. THe regulations regarding mains power wiring, installation and inspection in the UK are some of the strictest in the world. If an appliance on a power outlet causes 'sag' of the mains voltage and restriction of power available, time to call in the electrician because something in the building will be getting very hot and posing a fire risk. Edited by kedwardsleisure - 28 June 2022 at 2:16pm |
North Staffordshire |
EmPro
This is the reason why they invent the soft start,tyred of melted/welded/shorted/blow up power switches
EmPro Audio
levyte357-
This is quite frequent, and so very scary. I've played large number of gigs in venue with mate, where we monitored current draw of 2x MA5000VZ, on same ring main, and we permitted no more than 29A, and they could do this without voltage dropping below approx 239V. Same venue, different day, same setup, and if another crew were playing in a different hall, we could not draw > 20A, before mains voltage dropped below 230V !!!
EmPro
Speaking of,my last achizition,got it this morning as pictured,the left ear rack broken by UPS c_nts....but however the ampifier really looks like new inside and outside,bias was way off grid,after adjustments the amp is working flawless,i will still however resolder both amplifier stage boards as i don't like how they look compare to my other MT-s.
Edited by EmPro - 29 June 2022 at 12:08pm |
EmPro Audio
