  New Posts New Posts RSS Feed - made in China (by a 7yr old i would guess)
doller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doller Quote  Post ReplyReply Direct Link To This Post Topic: made in China (by a 7yr old i would guess)
    Posted: 13 September 2017 at 9:46am
Hosa cable. I shudder to think what age the person was that solderd this. Needless to say I won't be buying this brand again.
mini-mad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 13 September 2017 at 10:09am
Brand?... tell us so we can all avoid it please
Post Options Post Options   Thanks (0) Thanks(0)   Quote doller Quote  Post ReplyReply Direct Link To This Post Posted: 13 September 2017 at 11:59am
It's a 'Hosa' brand. I got it from Soundhouse. In future I am going back to making my own. This was bought to link the DJM to the mixer line in. I had trouble this weekend opened it up and found that. Surprised Soundhouse are usually pretty good. Maybe an own brand thing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 13 September 2017 at 12:53pm
At least you were able to open it up & repair. A lot of those use sealed connectors that are impossible to open. And the section there looks good. I´ve seen some (mainly RCA-RCA) that are made with around 2 strands of hair-thin copper/feed.   Ouch
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elliot Thompson Quote  Post ReplyReply Direct Link To This Post Posted: 13 September 2017 at 1:30pm
I am shocked to see such work from "Hosa" as they have been around for decades. You should contact them on your findings. http://hosatech.com/
Best Regards,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 13 September 2017 at 1:36pm
To be fair, ive got absouluty loads of diff cables like these from over the years branded and unbraded so to say, and new ones,
tha mostly all very good tbh, nice solder , very neat close to the solder tabs ect so tha cannot touch each orther
we all have off days
Edited by Dub Specialist Sound - 13 September 2017 at 1:37pm
_djk_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 13 September 2017 at 10:24pm
I buy cheap cables with good connectors, and then check every one before use.
These ship for free, and sell for less than I can buy the connectors for.
Edited by _djk_ - 13 September 2017 at 10:47pm
djk
GAZ. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GAZ. Quote  Post ReplyReply Direct Link To This Post Posted: 13 September 2017 at 11:36pm
I generally only make my own. Decent quality cable and neutrik connector. The only others I've got are blue Arans own ones which seem very good for the money, and they warranty them I believe. False economy buying cheap cables, doesn't look good on you when the lead singer drops out after moving a cable.
100% Earth Moving Bass
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 14 September 2017 at 12:15am
What part of 'I buy cheap cables with good connectors, and then check every one before use.' didn't you understand?
djk
Post Options Post Options   Thanks (0) Thanks(0)   Quote doller Quote  Post ReplyReply Direct Link To This Post Posted: 14 September 2017 at 6:12am
I usually by 'Canare' cable and make up my own. was lazey in this case. Like djk said cheaper that buying the conectors. This was a pair packaged seperatly. The other one was near the same. Soundhouse cheapo cables have plastic sleeve on the pins. Hosa don't by all accounts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 14 September 2017 at 11:06pm
I have to re-work about one-in-ten of the cheap cables I buy.
So what?
They come in six different cable colors, and have three different colors of heatshrink.
In the end, it saves time and money to buy them and check every end.
djk
Post Options Post Options   Thanks (0) Thanks(0)   Quote RoadRunnersDust Quote  Post ReplyReply Direct Link To This Post Posted: 15 September 2017 at 7:32pm
This. Using cheap shitty cables gives you no recursible chain of supply.
WHEN you get a random cable failure as GAZ described, being able to turn around and say 'it's a Belden/Sommer/Kelsey/etc cable with neutrik/switchcraft/etc connectors.' There's not much more anyone could expect you to have done to prevent the failure. Saying 'it's cheap shitty cable but I checked it before we used it!' Just makes you look like a shambles.
