Marquee Audio System |
Post Reply | Page 12> |
logicT
New Member Joined: 20 May 2018 Status: Offline Points: 5 |
Posted: 20 May 2018 at 10:09am |
Hi All,
I've been trying to research speakers and amps, for my wedding next month, and for an amateur it's a minefield! I would have just rented one, but we are getting married in France, and heading out early and coming back late, so the cost ends up pretty ridiculous; so the plan is to buy one, and then hopefully sell it on afterwards. Could anyone offer any advice as to what the best thing to get is? I've seen speakers with build in amps, seperate amps, seperate mixers, and power ranges from hundreds to thousands of watts. I think i may need around 2 x 200 watts continuous, does thi seem about right.
We have a band coming to the wedding, but they cant stay long enough to use their system for the whole night unfortunately. The guests will hopefully be worse for wear by this point and as such 'average wedding-DJ sound quality' is probably ok! Theres a guy on gumtree selling a Peavey XRD680 with 2 HiSys 2xt speakers (plus a monitor) for £250, is this any good? Any advice at all would be most welcome!
mini-mad
For 300 quid you could get a low priced dj to do all the work for you....
mk2_ginger_biscuit69
ahhh the old. this speaker malarky is easy ill just do it myself. Biggest and usually one of the most stressful days of your life is possibly not the time to start playing with speakers.
stop being tight and hire someone! |
Hemisphere
Not much resale value on hiring a DJ though.
Peavey HiSys 2xt regularly sell in pairs for less than 100 quid. The setup you mention doesn't sound too bad provided they're in decent condition and comes with everything else you need to get it running (stands and cables minimum). Then 250 is about right, and you can sell it on without much trouble. You can do better by buying a higher quality system. Mackie, LD Systems, dB Technologies, even HK Audio at the higher end - if you're going to sell it straight on anyway then buy what you can afford - It's your own wedding after all, not a hire job! In order to gauge whether you're getting a bargain or not, use eBay's 'completed listings' search feature. Most big brands have enough viewable sales in the last few months to give you a solid idea of their true value.
logicT
Cheers to all for the really quick feedback! It's really not to do with being stingy, its just a case of finding a suitable DJ in rural France. One that i got in touch with even asked us to supply a PA system!
I'll have a bit of time to test out the system beforehand, and the band has also offered to help set up our system before they leave, which is kind of them. I'd much rather the band stay and do the lot, but they are a 5 piece and travelling from the UK, so it ends up quite expensive. Thanks for the advice hemisphere, that's pretty much exactly what I'm after - I'll look into some equipment from those brands and see whats out there, so thank you! |
nickyburnell
Those Peavey's sound better than a lot of the Plastic Mackie's. Mate has some on an old school amp and is forever complimented on the quality by (small) venues. Cheap plastic powered stuff and some named have no mid. in the last months I've had a pair of Mackie Thumps through here and at mo is a pair of Samson. One thing in common, they sound sh it. Peavey's sell on Gumtree, band and solo singers love them.
Hemisphere
https://www.ebay.co.uk/itm/hk-audio-PA-speakers/222984599430?hash=item33eaeaf786:g:VFYAAOSwJTta8Fq~
You could do a lot worse than a pair of these. Pair of 'proper' professional 15" tops. Add a mixer and amp or powered mixer and a couple of stands and you're not much over planned budget. Night and day difference vs the Peaveys. This model is still in production/retail. The auction's just gone up, and at this price you could probably flip these for a small profit.
Hemisphere
Mackie Thumps are awful. SRM's are hit and miss as they switch component suppliers and change the design a lot, but I've heard some sound half decent.
I'm not a fan of the Peavey sound but I can see it's appeal.
I-shen Soundboy
Registered User Joined: 21 December 2016 Location: Big Smoke Status: Offline Points: 375 |
Be careful with speakers + vans + France.
Some ravey types have had grief from Les flics recently, some recent legislation making some combination of speakers and vehicles illegal. Although, if you're not taking an old bus piled high with a rig, you're probably not what they're looking for.
Edited by I-shen Soundboy - 20 May 2018 at 7:09pm |
logicT
Those HK's look smart, will have look and see if there's a reasonable amp about to go with it. Bit far away mind, but not ridiculous.
Thanks for the heads up on the police - if they stop me they will have to dig through piles of fairy lights, candles, and all the other random paraphernalia that don't even cross a blokes mind.
JonB67
The peavey hisys 2xt stuff is good for the money it commands. I worked with a guy that used it a few years ago. Its big and not exactly light but if you could beat them down to 200 then you'd have a winner.
krazyneil
Young Croc Joined: 06 December 2007 Location: Bolton ,lancs Status: Offline Points: 1206 |
this would power them fine on the cheap
GOD TOLD ME TO DO IT !!!!!
