Martin 215mk3 with pics |
Page <12345 7> |
discosucks ![]() Old Croc ![]() Joined: 06 November 2009 Status: Offline Points: 1548 |
Awesome!!
wilidapili ![]() Registered User ![]() Joined: 13 August 2018 Location: Finland Status: Offline Points: 56 |
Thanks for all the photos, looks like you'll have them running in no time!
Sooooo I discovered the stupid mistake I had made after I modelled the cab again, hehe. It was the side panels' length: I had drawn it to be 910, but it is 18mm shorter. This resulted in the 16mm difference in the drawing. I also scaled the original drawing in illustrator to quite closely match the real-life measurements to check the angles and lengths of the corner braces. Both of the braces are 45 degrees with the back panel. The brace touching the baffle is about 62mm from the back panel to the longer corner of the brace, like shown in the photo.
![]() On another note, have I understood correctly that the baffle and side panel look something like this? ![]() |
Father-Francis ![]() Old Croc ![]() ![]() Joined: 24 October 2007 Location: Kenya ,Denmark Status: Offline Points: 2700 |
that’s good you gotten that problem solved am on number five now , should be done tomorrow 😊
Waipy ![]() New Member ![]() Joined: 02 October 2018 Location: Barcelona Status: Offline Points: 4 |
Hello there, nice to find this post as I have the same plans and going to start building a pair these days. Nice boxes you have there :) Let me ask you, how are you connecting the speakers internally? in this cab the speakers are supposed to be connected in parallel into one output in the back of the cab, but i cannot get to the idea of how to do this. Could you show some photos? Would be very appreciated. And by the way, thanks to all the users in here, been reading this forum for years without writing and has helped me a lot.
Thanks for the answer, but I explained myself wrong. The question is: how are you gonna handle the wiring between drivers and the speakon? I cannot figure how to do the conexion withouth drilling the internal panels.
DMorison ![]() Old Croc ![]() Joined: 14 March 2007 Location: Aberdeen Status: Offline Points: 1527 |
You do drill the internal panels, route the wire through, then fill the hole with sealant if there's any gaps.
That clears everything, thanks.
Digbethdave ![]() Registered User ![]() ![]() Joined: 16 November 2018 Status: Offline Points: 394 |
Check out ace vintage systems, he has at least 24 original boxes, that he has improved
FOO ![]() Young Croc ![]() ![]() Joined: 23 December 2018 Location: Denmark Status: Offline Points: 629 |
Would it be possible to get the plans and files for this cab? I Havent seen these plans with double baffle before.
I would like to make them in singles.. Is this a good idea or does the drivers share the horn?
The drawing is here http://hornplans.free.fr/martin_mk3.html The other plans you have to try figure out yourself
boots-hifi ![]() Old Croc ![]() ![]() Joined: 15 August 2011 Status: Offline Points: 2426 |
No such thing as a free lunch!
Page <12345 7> |
