Martin 215mk3 with pics |
Page <1 23456 7> |
Father-Francis ![]() Old Croc ![]() ![]() Joined: 24 October 2007 Location: Kenya ,Denmark Status: Offline Points: 2755 |
You right about that Boots, we are a group of people working,on the system , I build someone draws so all team work . Nobody is going to be happy with me for giving their work out for free, companies here will charge around 3800kr to do a drawing like that .
FOO ![]() Young Croc ![]() ![]() Joined: 23 December 2018 Location: Denmark Status: Offline Points: 726 |
I am not asking for a free lunch. I can do it by myself.
But that drawing does not tell it all. Its missing materiale thickness. Quite important π And the Detail A do not give much information on where it is, and what it is. I can figure out its the baffle and the circular pattern is a cutout for the driver surround. But No info on how deep it should be. Some rather important measurements if you ask me π And then i can see you made double thickness baffle. Not a part of the plan. So that must mean some changes in volume and so on π I understand that alot of work had been put into it. And I do not ask for help for free. I am happy to pay for help. No questions about that π Cutting files and all that are not needed. But a detailed drawing that is complete would be a better starting point βΊοΈ 3800kr for a drawing doesnt sound totally out of the Ball park. Technical Engineers Arent cheap labor.. And the coffee dont Come cheap other π Father Francis, are you based in scandinavia since you use kr? π
wilidapili ![]() Registered User ![]() Joined: 13 August 2018 Location: Finland Status: Offline Points: 56 |
- Material thickness is 18mm - If you read the whole thread with thought, you could see from posted photos where "Detail A" is. As I did a double baffle, I made the "letterbox" (rectangular hole) into the other 18mm ply, and the circle cut-out on the other 18mm ply. The circle cut-out was as specified on used drivers' measurements for "rear mount baffle cut-out". I didn't make any other groove for the driver to sit in "deeper" in the baffle. If you want that, you need to freestyle it yourself. - Double thickness baffle changes the volume of the space where the driver is mounted, yes. How does it affect the end result? I don't really know...
am in CPH the thing is old cabs were done in 15mm finer I prefer to use 18mm ,and where possible , I make 2x18mm , makes my cabs sound better , hvor er du henne i Denmark ?
If its okay im gonna send you i mail.. Easyer to write in danish π
Edited by FOO - 26 December 2018 at 12:42pm |
IvCu ![]() Registered User ![]() Joined: 16 August 2014 Location: Netherlands Status: Offline Points: 26 |
Here, this will make some things easier. Be careful with angles and double check, good luck! |
Wow, thanks IvCu!!
Well i guess i have to learn how to use Sketchup then :D I got Autodesk Inventor, so i will get cracking with sketcing and converting that file to Inventor instead.. Looks nice and tidy! Thanks again man! |
No worries!
It's also possible to convert this file to cnc compatibility as well ;)
Well i will have a go at it :D
Can see that the double baffle is made out of 15mm sheets. Do you know any way to convert it directly. That would save me some time.
Still have a bunch of work to do, double checking the whole thing :D |
I got your mail, am at some Julefrokost , will reply as soon as I get home , you still didnβt say where you are Boss is it CPH too?
Thats fair :D
Gotta get that snaps and sild down the hatch before it gets bad :D My bad.. Im based in Aarhus. Or rather just outside... |
Is it a go or no-go to make them as halfs?
The middle divider doesnt go all the way to the front, so the drivers share the horn in some way ?
Page <1 23456 7> |
