Martin 218 Copies |
Page <12 |
Digbethdave ![]() Registered User ![]() ![]() Joined: 16 November 2018 Status: Offline Points: 394 |
Just bear in mind BSX are really deep when laid flat.
levyte357- ![]() Old Croc ![]() ![]() Joined: 27 July 2012 Location: UK, South East Status: Online Points: 7450 |
Got the 4x delivered tonight, very heavy, even when unloaded... Lovely..
Edited by levyte357- - 06 February 2020 at 11:10pm |
madboffin ![]() Young Croc ![]() Joined: 03 July 2009 Location: Milton Keynes Status: Offline Points: 1491 |
The original BSX (when I worked there) was fitted with a pair of 8 ohm RCF L18-851 drivers. The RCF was later replaced with a custom Celestion and somewhere on speakerplans there are a couple of threads about the various drive units used by Martin in the 1980's / 90's.
There was a JBL 18" that worked very well in these (can't quite remember the number, 2240 maybe?), but obviously not an option these days. The box was sized to fit underneath an RS1200 one-box system and if you ever encounter one of those you will discover the real meaning of the word "heavy"... Now you have the boxes and dimensions, simulation is the way to go. Edited by madboffin - 06 February 2020 at 11:44pm |
How far did you get with the BSX?
I'm currently looking at the rcf and the celestion, that would of ended up in BSX.
Update. Have had very disappointing results with certain 18sound reflex driver. Further research indicates Fane Colossus 18B400 was a flyer in this cab. However, to make this cab worth it's space, I need pair of optimal 1kw drivers in each cab. Amplifier power is not a problem, neither is venue power... (For once) Currently considering Fane Colossus Prime 18XS/ B&C 18TBX100 Edited by levyte357- - 25 January 2022 at 1:43pm |
smitske96 ![]() Young Croc ![]() Joined: 16 February 2016 Location: The Netherlands Status: Offline Points: 867 |
Do you know the cabinets tuning and volume?
And which 18sound driver did you test?
2x cabs are loaded in venue, other cabs are unloaded, in locked room under pile of gear, so no measurements made, to allow sims.
Compared to recommended drivers, the parameters of drivers I bought were very different. Looked at parameters of Fane 18B400, found some very similar with higher power rating. |
toastyghost ![]() The 10,000 Points Club ![]() ![]() Joined: 09 January 2007 Location: Manchester Status: Offline Points: 10669 |
So your time to drag them out, fit some random drivers and play some tunes - more than once - apparently costs less than getting one out to do measurements?
Edited by toastyghost - 26 January 2022 at 12:38am |
Tried the 18sound 18LW2420, myself and FOH Engineer, found them acceptable, but not impressive, in this cab.
Another PA Dude has recommended Fane 18XS or B&C 18TBX100. Edited by levyte357- - 23 May 2022 at 6:28pm |
Page <12 |
