  New Posts New Posts RSS Feed - Martin Audio 115
Martin Audio 115
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2016 at 11:36pm
yeah now we can start jokes that you need a sub instead lol
horn loaded for her pleasure
empiresoundsystem View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote empiresoundsystem Quote  Post ReplyReply Direct Link To This Post Posted: 08 December 2016 at 6:30am
Well to be pedantic WinkLOL
Frequency RangeFrequency Values
Sub-bass20 to 60 Hz
Bass60 to 250 Hz
Low midrange250 to 500 Hz
Midrange500 Hz to 2 kHz
Upper midrange2 to 4 kHz
Presence4 to 6 kHz
Brilliance6 to 20 kHz
Failed DJ and fumbling through the world of pro audio. Give me a thumb and make me feel better:
www.facebook.com/empireAVWorks
Post Options Post Options   Thanks (0) Thanks(0)   Quote empiresoundsystem Quote  Post ReplyReply Direct Link To This Post Posted: 08 December 2016 at 2:24pm
Originally posted by empiresoundsystem empiresoundsystem wrote:
Originally posted by Robbo Robbo wrote:
Martin Audio 115s are still one of the best bass/kick bins going as long as you don't expect them to do sub.
You do have a couple of problems here though as the Fanes are a waste of space in that cabinet and will self destruct with torn cones---You need drivers with very thick and heavy cones to get the best out of them, something along the lines of PD1550 which kick like a mule in them.
The cabinets also look very much like copies especially when looking at the thin spindly handles on the top two cabinets---there are one hell of a lot of copies of these boxes about and are very often quite poorly and wrongly built in the compression section at the back of the cabinet.
You can virtually stick any driver inside and these cabinets will sound "nice" but get a decent pro quality driver inside and you will notice one hell of a difference.
Hi Robbo, I don't think the 1550 Sims up as well. I do believe the bottom one is a copy. The top two are originals as they had the original badges on the horn mouth sides.
Althouuugghhhhhh that said Robbo, you might be right, looking at the ones on the original whitesheet, it appears my bottom one is an original and the top two are very good copies Sleepy The bottom one feels alot heavier too. Ahh god knows... I've also been chatting to some mateys on a facebook group I mod and the consensus does appear to be that the Fanes are a bit poo, and that PD1550 is the way to go for these cabs; and that simming sometimes has to be ignored!
Post Options Post Options   Thanks (0) Thanks(0)   Quote empiresoundsystem Quote  Post ReplyReply Direct Link To This Post Posted: 08 December 2016 at 2:28pm
aaaaaaaaaand on the bottom one, there was no original XLR link I/O, infact there was nothing, it went straight up the arse of the access panel oddly enough, so they might all be copies! LOLLOLLOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbl_man Quote  Post ReplyReply Direct Link To This Post Posted: 08 December 2016 at 3:21pm
Yup,bottom one is also a copy....Martin (or rather Tony ASS who actually built them for Martin) would never fit the top and bottom panels that badly.
Robbo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robbo Quote  Post ReplyReply Direct Link To This Post Posted: 08 December 2016 at 3:34pm
Yeah,45 years experience with these type of cabinets does tend to give me the edge over the young whippersnappers on the forum--Between me and Ian, we could probably even give you the exact screw spacings from when the cabinets were built
Post Options Post Options   Thanks (0) Thanks(0)   Quote empiresoundsystem Quote  Post ReplyReply Direct Link To This Post Posted: 08 December 2016 at 3:53pm
ehhh dear. At least they sound ok. :)
Mkmandy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mkmandy Quote  Post ReplyReply Direct Link To This Post Posted: 30 August 2023 at 10:47pm
Does somebody have a plan?
So i can make them myself??
KDW32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KDW32 Quote  Post ReplyReply Direct Link To This Post Posted: 31 August 2023 at 1:15pm
doller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doller Quote  Post ReplyReply Direct Link To This Post Posted: 04 September 2023 at 12:46pm
martin 115 drawing - Speakerplans.com Forums
I bought two originals and then copied them. The ones I have do not match the ones on hornplans. It was quite confusing.
The 115 looks like an easy build. It is not. Very time consuming. Very rewarding to listen too. I have build pics if you want. 6 took me 3 weeks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote doller Quote  Post ReplyReply Direct Link To This Post Posted: 04 September 2023 at 12:51pm
toebak View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote toebak Quote  Post ReplyReply Direct Link To This Post Posted: 07 September 2023 at 8:45pm
my brother in christ we made 1 in 2 days... its very easy to build try making a sbh or xtro
This page was generated in 0.059 seconds.
