  New Posts New Posts RSS Feed - Martin Audio F1/F2 system
Jimmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jimmer Quote  Post ReplyReply Direct Link To This Post Posted: 22 August 2015 at 8:45am
Hi Dave
Its been a crazy year work wise, so unfortunately spare time has been hard to come by to finish this project. I think once festival season is over I will be able to firstly finish the crossover and amplifier refurb, then look at making some jigs up and getting some F2b's knocked up. It will happen...I'll use this thread as a progress log Thumbs Up
Edit* .... I was also thinking about putting the mid Hi horns into separate boxes to make them a more manageable lift! they are silly heavy!
Edited by Jimmer - 22 August 2015 at 8:49am
RUS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RUS Quote  Post ReplyReply Direct Link To This Post Posted: 22 August 2015 at 1:44pm
Is that one of the seven sins
Thou shell not discostruct Martin audio
njw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote njw Quote  Post ReplyReply Direct Link To This Post Posted: 22 August 2015 at 9:54pm
Originally posted by all bass all bass wrote:
That's a proper steal.
Praise the lord for needing new equipment to be worshipped with...
 Amen brother!
That's a billy bargain if I do say so myself, especially with all intact original drivers and working passives.Clap
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jimmer Quote  Post ReplyReply Direct Link To This Post Posted: 23 August 2015 at 10:57am
Ha ha, I'll always keep the original carcasses. They are just very heavy and difficult to splay when they are a cube! Now I have the extra top boxes it would be nice to have them in trap cabs to splay them easier. Or maybe a similar layout to the d&b c4? Also If I was to separate the hf and mid, I could also add a tilt system to easily angle the hf section down to minimise reflections etc...
Motion54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Motion54 Quote  Post ReplyReply Direct Link To This Post Posted: 14 December 2015 at 12:21pm
Talking of splitting, I wonder how the F2 would fair if spilt into 2.
I think this would assist in moving them around and keeping ones spine intact.
But would the sound change considerably?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jimmer Quote  Post ReplyReply Direct Link To This Post Posted: 14 December 2015 at 6:43pm
You talking about F2 tops or F2b bins Jase?
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 14 December 2015 at 6:49pm
F2 tops were originally a modular design so you could probably very easily separate the components and it'd not be much different to how it was used in the first place.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Motion54 Quote  Post ReplyReply Direct Link To This Post Posted: 14 December 2015 at 8:43pm
I meant F2b's.
This would be ideal as singles
bass*en*mass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Posted: 14 December 2015 at 8:48pm
cant see any issues with the cabs layout if cut in half.. resale value might drop though
Post Options Post Options   Thanks (0) Thanks(0)   Quote Motion54 Quote  Post ReplyReply Direct Link To This Post Posted: 14 December 2015 at 9:14pm
You might be right.
Been told that the magic of this box is assisted by the coupling of the 2 drivers in the shared horn mouth.
I wouldn't wanna lose this effect in an unrecoverable way, even when split and then coupled when stacked as 2.
djeddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djeddie Quote  Post ReplyReply Direct Link To This Post Posted: 14 December 2015 at 10:03pm
F2B's cut in half? Nope! The horn is a bifuricated horn. It's two separate throats that share one mouth... meaning the horn can't be cut in half.
Trying to find the link to the same question being asked on another forum... but failing at the mo.
Edited by djeddie - 14 December 2015 at 10:04pm
Robbo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robbo Quote  Post ReplyReply Direct Link To This Post Posted: 14 December 2015 at 10:13pm
F2B is only a tiny little bin anyway so I cannot see the point.
