  New Posts New Posts RSS Feed - Martin Audio F2B
Martin Audio F2B
Ibex View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ibex Quote  Post ReplyReply Direct Link To This Post Posted: 19 April 2010 at 10:40pm
Originally posted by Heathrow_B_line Heathrow_B_line wrote:
can you sim it with a pd1550?
...see comparison of different drivers for the 215 MKIII, bloody similar for the F2B.
Note:
PD drivers doesn't fit into a nonmodified F2B!!!
PD154 would be the best choice, in this case you would have to increase the depth of the rear chamber to make the driver fit.
Only RCF L15-554K/L15P200AK and JBL 2226H fit in without modification.
bitzo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitzo Quote  Post ReplyReply Direct Link To This Post Posted: 21 April 2010 at 10:05am
Ibex how do you get the input for hornresp? Just a 215mk3 with 6" shorter lenght?
Ibex View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ibex Quote  Post ReplyReply Direct Link To This Post Posted: 21 April 2010 at 1:09pm
No mate, I just hired one and measured it...
BTW, there is nothing about 6" shorter length.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitzo Quote  Post ReplyReply Direct Link To This Post Posted: 21 April 2010 at 2:36pm
6" just seen on f2 system datasheet. False clue from Martin.
Ibex View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ibex Quote  Post ReplyReply Direct Link To This Post Posted: 21 April 2010 at 2:54pm
...I can't comprehend what they have writen in the datasheet.
Edited by Ibex - 21 April 2010 at 2:56pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitzo Quote  Post ReplyReply Direct Link To This Post Posted: 21 April 2010 at 3:03pm
lol. your method is better at all.Thumbs Up
snowflake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 03 January 2015 at 5:01pm
RCF LF15X401 should fit in the F2B
djeddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djeddie Quote  Post ReplyReply Direct Link To This Post Posted: 03 January 2015 at 7:17pm
Well it's the same depth, so physically it should go in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 03 January 2015 at 9:17pm
sims 12dB more max output than the ATC driver
Post Options Post Options   Thanks (0) Thanks(0)   Quote djeddie Quote  Post ReplyReply Direct Link To This Post Posted: 04 January 2015 at 12:48am
That doesn't sound right to me! One or two dB maybe, but 12dB???
I've got the F2B's that Robbo mentioned earlier, (the copies with a bigger rear chamber), they're currently loaded with an EV driver and they're stupidly sensitive. There's hardly any noticable difference to the ATC's as I've tried them side by side, so 12dB on that would be defying the laws of physics.
And no, I'm not going to make a Star Trek joke about you 'can'ne change the laws of physics, Jim'. That would be highly illogical.
Edited by djeddie - 04 January 2015 at 12:48am
KidCreole View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KidCreole Quote  Post ReplyReply Direct Link To This Post Posted: 04 January 2015 at 12:51am
Miracle
Mykey Wattco
corell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corell Quote  Post ReplyReply Direct Link To This Post Posted: 04 January 2015 at 1:13am
+12db would mean 4 times the cone displacement. so if the ATC has xmax around 3mm, this could be true...
