Martin Audio RS800 |
Post Reply | Page 12> |
fedevi
Registered User Joined: 03 April 2008 Location: Italy Status: Offline Points: 2 |
Posted: 03 April 2008 at 12:14pm |
Hello,
my name is Federico and I'm from Italy. Excuse me for my bad english eheh.
I've 8 beautiful Martin RS800 and I'm looking for a good subwoofer. I try with some solutions: jbl wbin, double bass reflex 18" but for me the result is not very good (I use these system for dance music). I'm looking to make a similar Martin FSX, or similar d&b B2 or JBL TCB. What you think? What is the best solution?
I drive the system with:
BSS 336 minidrive for the RS800 with all QSC MX power amps.
For the sub I can use BSS 334 minidrive with qsc or crown ma power amp or crown xti4000 with internal dsp.
I hope in your help.
Greetingz from Italy!
ceharden
There are plans on here for the Martin WSX, probably your best bet.
fedevi
Thanks for the fast reply ceharden. Where can I find the WSX plans?
ceharden
Just remembered I made a local copy here.
Do a search for WSX on here, lots of discussion about them. |
davided4d
New Member Joined: 27 March 2018 Status: Offline Points: 9 |
Ciao Federico, io ho un impianto Martin Audio RS800 Completo 4 x Rs800 e 2 x BSX218 doppio sub, vanno abbinati per dargli il giusto suono i cross-over MX4 pilotandoli in quadri amplificazione cioè con lo switch sull'rs800 del tweeter posizionato su attivo
Ora io li piloto in triamplificazione con i finali originali Harrsion Compu-tek e Lab Groupen 1300c+ un Alto Mac 2,3 per i sub e come cross-over uso non gli mx-4 in quanto non trovo le schede di delay originale, per l'allineamento in fase ma un comune behringer cx2310, l'allineamento in fase lo faccio aiutandomi con il software smaart7 e le correzioni di delay tramite un multieffetto sulla FHO o dal banco mix digitale. Quindi per farti capire meglio uso il lab groupen e l'harrison compu-tek 1200 per i medio alti, mentre per le basse con cross-over tagliato a 250 Herz Harrison compu-tek 2500 e XI 2000 Ti chiedo se hai i componenti originali di postare akcune foto grazie
BANG
Registered User Joined: 22 March 2021 Status: Offline Points: 14 |
Ciao Davide.
Ho acquistato io impianto Federico, fatto UPGRADE TOTALE, BASSO, ho costruito 218, con stesso disegno RS800, in pratica vedi lo stesso cabinet con 2x18. Ho alcune foto pezzi originali.
davided4d
ok posta foto
davided4d
dimenticavo fai una descrizione il più completa possibile di cosa hai fatto all'impianto sono curioso di vedere il risultato magari anche un video
BANG
Ciao, discorso molto lungo che non mi sembra caso postare, ev. se c'è modo contattami direttamente.
scrivo solo 2 cose x UPGRADE: 1 RCF L18S801 RCF L12L750 BC SPEAKERS M60+DE750TN 2 RCF L18P400 BC SPEAKERS MH32 BC SPEAKERS M60+DE750TN 218 RCF L18P400 Questi componenti scelti dopo vari TEST e confronti con amico che aveva RS1200 Mio UPGRADE preferito 2
BANG
dimenticato
BSS MINIDRIVE 336 taglio 200 - 1200 |
davided4d
Giusto per completare, ma il cross-over interno? l'hai tenuto o lo hai modificato???
BANG
tolto, solo attivo, sostituito conn. con SPEAKON
amp. CREST CA 18-12-9-6 |
