Martin audio settings spreadsheet limiter |
dark_m4n
Registered User Joined: 01 February 2013 Status: Offline Points: 47 |
Posted: 24 February 2019 at 8:32am |
Hi !
I t may seem a rocky question but I hope to better understand Martin W8LM settings, not having the same sound guy every time it's hard for me and I need to double check settings sometimes.
I own a: 10 x W8LM ( 5/ side ) 6 x W8LMD ( 3/side or 2/side + frontfills down ) 8 x WSX 4 x WMX ( 2/side flown at the top ) All powered by Martin DX2 processors. Looking at the loudspeaker spreadsheet I need to better understand the limiter settings, there is a threshold and a peak limiter, in the DX2 I see a limiter and a clip limiter, I believe threshold is the value of the limiter and the peak limiter is the clip limiter ? Is this correct ? I usually hang the WMX subs at the top and delay them with 2.430ms in order to align them with the WSX/W8LM, is this the right approach ? I concluded this by looking at the spreadsheet: WSX LF delay = 5.933 WSX HF delay = 5.831 WMX LF delay = 3.502 WMX HF delay = 3.401 I ended up delaying the WMX 2.430ms by calculating 5.933-3.502=2.431 ( subtracting delay from WSX and WMX ), don't know if this is right :(. My logic was to delay the WMX more in order to compensate for the shorter horn length compared to the WSX. Thanks, Mihail. |
