Martin Audio W3P about? |
mgftrophy
Joined: 20 November 2013 Location: Oporto Status: Offline Points: 103 |
Topic: Martin Audio W3P about?Posted: 21 September 2014 at 12:14pm |
Does the Martin Audio W3P run passive mode fullrange? or only bi-amp?
I have a offer on 2 x Martin Audio W3P mint for 400€ the two, does the W3P compete in the same league of a JBL SP215-6 or is a better speaker more headroom due to is horn load mid-hi section? I have 4 JBL SP215-6 and I know the output they have, just want to know how Martin W3P compare to the JBL SP215. I know JBL is 600Watts rms speaker, and W3P says 400W aes? the more power not always can give more headroom , don´t you think? Regards Jorge .
mgftrophy
Posted: 21 September 2014 at 12:22pm |
in the Martin Pdf manual says :
W3P TYPE Compact bi-amplified 3-way trapezoid FREQUENCY RESPONSE 55Hz-18kHz ± 3dB LOW FREQUENCY LIMIT -10dB @ 45Hz DRIVERS 15” (380mm) / 3” (75mm) voice coil 6.5” (165mm) horn loaded mid-range 1” (25mm) exit HF compression driver RATED POWER LF: 400W AES, 1600W peak MF/HF: 150W AES, 600W peak RECOMMENDED AMPLIFIER 400-600W into 4 ohms from the read above , I understand that the W3P is 550Watts AES in Passive mode Fullrange? Why they rated them 400W aes in some papers? |
djeddie
Posted: 21 September 2014 at 1:47pm |
If it was me, I'd have the Martin Audio cabs over the JBL any day of the week.
cravings
Joined: 30 January 2007 Location: Ireland Status: Offline Points: 7507 |
Posted: 21 September 2014 at 5:34pm |
€400 would be a total steal if you got them for that.
i have the bi-amped W3... they're nice. |
mgftrophy
Posted: 21 September 2014 at 9:56pm |
What do you mean a total steal if you buy them for that? You think that is a bad deal for 400 € for the 2x Martin w3p?
Regards Jorge. |
djeddie
Posted: 21 September 2014 at 10:37pm |
No! A very, very good price! You got a bargain.
mgftrophy
Posted: 21 September 2014 at 11:53pm |
Thanks Eddie.
