  New Posts New Posts RSS Feed - Martin Audio W3P about?
mgftrophy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mgftrophy Quote  Post ReplyReply Direct Link To This Post Topic: Martin Audio W3P about?
    Posted: 21 September 2014 at 12:14pm
Does the Martin Audio W3P run passive mode fullrange? or only bi-amp?
I have a offer on 2 x Martin Audio W3P mint for 400€ the two, does the W3P compete in the same league of a JBL SP215-6 or is a better speaker more headroom due to is horn load mid-hi section?
I have 4 JBL SP215-6 and I know the output they have, just want to know how Martin W3P compare to the JBL SP215.  I know JBL is 600Watts rms speaker, and W3P says 400W aes? the more power not always can give more headroom , don´t you think?
Regards Jorge .
Post Options Post Options   Thanks (0) Thanks(0)   Quote mgftrophy Quote  Post ReplyReply Direct Link To This Post Posted: 21 September 2014 at 12:22pm
in the Martin Pdf manual says :
W3P
TYPE Compact bi-amplified 3-way trapezoid
FREQUENCY RESPONSE 55Hz-18kHz ± 3dB
LOW FREQUENCY LIMIT -10dB @ 45Hz
DRIVERS
15” (380mm) / 3” (75mm) voice coil
6.5” (165mm) horn loaded mid-range
1” (25mm) exit HF compression driver
RATED POWER
LF: 400W AES, 1600W peak
MF/HF: 150W AES, 600W peak
RECOMMENDED AMPLIFIER 400-600W into 4 ohms
from the read above , I understand that the W3P is 550Watts AES in Passive mode Fullrange?
Why they rated them 400W aes in some papers?
djeddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djeddie Quote  Post ReplyReply Direct Link To This Post Posted: 21 September 2014 at 1:47pm
If it was me, I'd have the Martin Audio cabs over the JBL any day of the week.
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 21 September 2014 at 5:34pm
€400 would be a total steal if you got them for that.
i have the bi-amped W3... they're nice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mgftrophy Quote  Post ReplyReply Direct Link To This Post Posted: 21 September 2014 at 9:56pm
What do you mean a total steal if you buy them for that? You think that is a bad deal for 400 € for the 2x Martin w3p?
Regards Jorge.
Post Options Post Options   Thanks (0) Thanks(0)   Quote djeddie Quote  Post ReplyReply Direct Link To This Post Posted: 21 September 2014 at 10:37pm
No! A very, very good price! You got a bargain.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mgftrophy Quote  Post ReplyReply Direct Link To This Post Posted: 21 September 2014 at 11:53pm
Thanks Eddie.
