  New Posts New Posts RSS Feed - Martin Destroyer X250 Problem
cuivenion View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cuivenion Quote  Post ReplyReply Direct Link To This Post Topic: Martin Destroyer X250 Problem
    Posted: 10 February 2013 at 7:04pm
I've got about 6 of these lights and two have stopped working recently with the same fault. Lamp comes on but neither of the wheels turn. The gobo wheel spins on start up to align and the stops. Is there a possible simple solution to this or am I going to have to bite the bullet and send them for repair?
help!!!!!!!!!!
djeddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djeddie Quote  Post ReplyReply Direct Link To This Post Posted: 10 February 2013 at 7:59pm
Where abouts in the UK are you?
Post Options Post Options   Thanks (0) Thanks(0)   Quote cuivenion Quote  Post ReplyReply Direct Link To This Post Posted: 10 February 2013 at 8:04pm
Morecambe mate, I'm off to work now so I can't reply till later on.
help!!!!!!!!!!
lgosdset View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lgosdset Quote  Post ReplyReply Direct Link To This Post Posted: 10 February 2013 at 9:46pm
do you have them on sound to light or are you controlling them with DMX?
If you are using them sound to light- get one of the working units, set it to master, and set the other non-working unit/s to slave, link them up and see if it jumps back to life when controlled by DMX. if so, then you have a problem with the internal microphone.
Edited by lgosdset - 10 February 2013 at 10:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote cuivenion Quote  Post ReplyReply Direct Link To This Post Posted: 11 February 2013 at 2:16am
Sounds like a plan I'll give that a try.
help!!!!!!!!!!
