Martin Destroyer X250 Problem |
cuivenion
Joined: 30 January 2005 Location: United Kingdom Status: Offline Points: 974 |
Topic: Martin Destroyer X250 ProblemPosted: 10 February 2013 at 7:04pm |
I've got about 6 of these lights and two have stopped working recently with the same fault. Lamp comes on but neither of the wheels turn. The gobo wheel spins on start up to align and the stops. Is there a possible simple solution to this or am I going to have to bite the bullet and send them for repair?
help!!!!!!!!!!
djeddie
Posted: 10 February 2013 at 7:59pm |
Where abouts in the UK are you?
cuivenion
Posted: 10 February 2013 at 8:04pm |
Morecambe mate, I'm off to work now so I can't reply till later on.
help!!!!!!!!!!
lgosdset
Joined: 28 September 2010 Location: Reading ish Status: Offline Points: 1203 |
Posted: 10 February 2013 at 9:46pm |
do you have them on sound to light or are you controlling them with DMX?
If you are using them sound to light- get one of the working units, set it to master, and set the other non-working unit/s to slave, link them up and see if it jumps back to life when controlled by DMX. if so, then you have a problem with the internal microphone. Edited by lgosdset - 10 February 2013 at 10:02pm |
cuivenion
Posted: 11 February 2013 at 2:16am |
Sounds like a plan I'll give that a try.
help!!!!!!!!!!
