  New Posts New Posts RSS Feed - Martin DLS 846 best usage
madam View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote madam Quote  Post ReplyReply Direct Link To This Post Topic: Martin DLS 846 best usage
    Posted: 18 July 2021 at 9:53am
Hi,
I just bought 6 x DLS846 (b&c 18 pzb100) as brand new, and also dls 15011 drver from a Blackline X115.
All brand new, from a Martin distr.
What would be the best usage of these?
Should I can build 3x S218, or 6 x WSX, maybe 1 reflex 4 horns, or 2 reflex, 2 horns.....or something else?
I know its 2 very different approach, S218 is better for indoors while WSX is better for outdoors.
Also known the WAXa is made with RCF 18P300, and it have better bottom-end, higher Cms, Rms, Mmd, Mms, lower BL and EBP, so works better in the horn.
Efficiency is way better for the B&C.3.1% while 2.3% for the RCF.
Also bought some Martin XE300 drivers so I will use those as tops, in a rotated config, and have 4 or 6 CDD’s also.
Any advise?
Edited by madam - 18 July 2021 at 9:55am
Post Options Post Options   Thanks (0) Thanks(0)   Quote madam Quote  Post ReplyReply Direct Link To This Post Posted: 21 July 2021 at 7:27pm
So it looks like the best would be to build the original S218 for these Martin woofers?
There is no other cabinet for these speakers ?
