Martin minimac profile help |
jamie-ashton-solo
Joined: 26 January 2009 Location: staffordshire Status: Offline Points: 728 |
Topic: Martin minimac profile helpPosted: 23 August 2017 at 3:47pm |
Looking for some help diagnosing one of my fixtures please. One of them has developed a fault where it will follow the others as normal for a few seconds and then the tilt will drop down and stutter, failing to move itself back up to facing ceiling position. First thought is the belt. I've taken apart and had a look but can't see anything obvious. Any help will be appreciated.
Jamie |
07756215776.
mk2_ginger_biscuit69
Joined: 03 November 2008 Location: Brighton Status: Offline Points: 7797 |
Posted: 25 August 2017 at 9:56pm |
if the belts ok, its simply either the drive or recieving cog teeth worn allowing it to slip, or the tensioner is slack [happens over time with stretching belt]. I tend to just replace the belt and tension accordingly - never had a cog too worn.
Been keeping these things going for 13years now!! |
