  New Posts New Posts RSS Feed - martinson tham 15
martinson tham 15
 Post Reply Post Reply Page  <1 23456 7>
AngusR9090 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AngusR9090 Quote  Post ReplyReply Direct Link To This Post Posted: 11 April 2017 at 12:45pm
Hi magic! any chance you could repost the cutting plan? It's not showing up for me.
MagicJohansson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MagicJohansson Quote  Post ReplyReply Direct Link To This Post Posted: 11 April 2017 at 2:04pm
Hi Angus
Looks like my website where all pictures are hosted is down, I will have too look into that.
Meanwhile, here is the cutsheet for now:
Here is also a link to a PDF with the same information: uploads/12282/Cutting_Diagram_for_THAM15_MK1.pdf
Post Options Post Options   Thanks (0) Thanks(0)   Quote AngusR9090 Quote  Post ReplyReply Direct Link To This Post Posted: 11 April 2017 at 2:14pm
Cheers. thats helped alot.
Now ... to build!!! Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote MagicJohansson Quote  Post ReplyReply Direct Link To This Post Posted: 11 April 2017 at 2:18pm
Oh, one hint. When You cut pieces #3 and #4 be very careful that You get the 464 mm exactly the same as parts 5 - 11. That makes the assembly much easier further on in the project :-)
Array206 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Array206 Quote  Post ReplyReply Direct Link To This Post Posted: 26 February 2018 at 11:37pm
Hello dear friend ..... looking for enclosure desing for the box 15lb100-8w I found the tham 15, by the way, a good option.But unfortunate encounter the three-way set designed with crossover at 250hz and 3.8khz.
1-Tham 15 is only viable up to 120 Hz (120-250 Hz is not covered by any driver). For this reason songs with high vocal content ... sound bad.
Instrumental deep house music with low vocal content may sound good.
2- The 3,8khz treble cut may have been made to maximize the maximum power and thus not have to put a 1.4 "horn. Your project would be viable with bass reflex that if it reaches 250hz.
3- To keep the tham 15 you could accompany it with a line array of 6.5 "double and treble horn in vertical plane (2 units 6.5" Beyma 6 cmv2 + 1 "cd10fe)
 crossovers tham 100 hz array 78hz-1200hz and treble 1200-20,000hz more parametric equalization.
4- mt112 is bad combination tb ... from 120 hz to 250hz is not covered by any driver.
There are more options depending on budget.
a greeting
Dutchman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dutchman Quote  Post ReplyReply Direct Link To This Post Posted: 13 April 2018 at 9:54pm
Hi mate, i used the cutting sheet from you and got some wood cut at the local timber yard. thanks for sharing. Do you maybe still have those tham 15 solid works drawings? Smile
We need more SPL!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MagicJohansson Quote  Post ReplyReply Direct Link To This Post Posted: 14 April 2018 at 7:40am
Hello Dutchman
I don't use Solidworks anymore but I should have a backup of the Solidworks-files somewhere, I will have a look and get back to You.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dutchman Quote  Post ReplyReply Direct Link To This Post Posted: 14 April 2018 at 12:34pm
Hello Dutchman
Thanks mate!
We need more SPL!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dutchman Quote  Post ReplyReply Direct Link To This Post Posted: 14 April 2018 at 12:36pm
Would the B&C 15NDL76 be a good choice to go in the tham 15? my preference goes to neo dymium due to less weight , better look and they keep their value better than 'old' speakers. and because we live in 2018 :)
We need more SPL!
malina View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote malina Quote  Post ReplyReply Direct Link To This Post Posted: 16 April 2018 at 8:01am
I think 15NW100 would be the choice here.
Correct me if I am wrong.
Malina Audio
Hemisphere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hemisphere Quote  Post ReplyReply Direct Link To This Post Posted: 16 April 2018 at 8:29am
They're both suitable. 15nw100 is better. 15ndl76 is a lot cheaper though. And half the weight.
Edited by Hemisphere - 16 April 2018 at 8:30am
Phase 1: Post on Speakerplans
Phase 2: ?????
Phase 3: Profit!
Angelow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Angelow Quote  Post ReplyReply Direct Link To This Post Posted: 11 July 2018 at 10:29am
hello I reopen the post for two questions:
Magicjhonson: the deflectors are mounted only above?
as I do not find the 15ps100 4 ohms (b & c is a holiday as production, only sells at the moment, will resume production in mid-September), that other economic drivers that are good on the tham (160 euros) exist 4 ohms? I should do 12 bass, spend 230 euros for 15nbx100 is too much!
This page was generated in 0.281 seconds.
