matching drivers to power amp |
spmike
New Member Joined: 23 July 2020 Status: Offline Points: 7 |
Posted: 25 July 2020 at 7:00pm |
Im building a setup with two midtops and two subs: midtops two way with 400W and 100W drivers subs with 800W drivers I'm intending to use a 4-channel power amp, 4 x 800W RMS into 8ohm I know the power amp will handle the midtops but is it enough for the subs? Thanks
Earplug
One common way of doing this is to bridge 2 of the 4 channels for the bass-end (in mono) and the mid-tops in stereo off the other 2 channels. Can the amp you have do that? And/or do the 2 subs in bridge, ie handle the 2 subs in parallel? Some amps may not like anything below 8 ohm in bridge. |
