Matching speaker ratings to amp power |
Post Reply | Page 123> |
Grubbah
Old Croc Joined: 14 July 2011 Location: Portsmouth Status: Offline Points: 2004 |
Posted: 08 March 2013 at 2:50pm |
Proper novice question here, but its driving me mad...
I was under the impression of one thing, just read and article and maybe the guys wrong, but ive heard a few contradicting things now and would love to just get this cleared up. So lets say my speaker is 300W RMS with a program power of 600W @ 8ohms. What would be the ideal amplifier power at 8ohms? I understand about underpowered amplifiers clipping and excessive power are the 2 main causes of speaker failure. I also understand the difference between RMS and program power. My thoughts would be between 400 - 600W so to allow for headroom in the amplifier and respond more to the the program power rating of the speaker as program material being amplifier isn't continuous pure tones... |
Radeon
Registered User Joined: 22 November 2011 Location: Croatia Status: Offline Points: 277 |
anything between 300w and 600w RMS ,depending on a program material and headroom requriements
Grubbah
So, bass heavy dance music... more towards 300W.... live music applications... more towards 600W? |
duck1
Registered User Joined: 22 February 2008 Status: Offline Points: 173 |
Depends what you're going to be doing with the system. A home cinema system will probably be ok with an amp rated at the RMS power of the speakers (or less if it's not ragged).
If it's for party/events, then it makes no sense if the amp has to work flat out all night. Twice the speaker's RMS power is probably a good start.
Grubbah
Mainly live music, though some dance too.
Im trying to build up an amp rack at the moment, and its quite a challenging scenario on my bass section. 4 x 8ohm bins, in total, 2400W RMS or 4800W program... cost variation in amplifiers around the 2 values is quite a lot. |
duck1
Maybe look for an amp that can give you 2k per channel at 4ohms or a pair that will do similar in bridge mode.
What's your budget for bass amps?
Old Croc Joined: 02 April 2004 Location: United States Status: Offline Points: 5176 |
You would be better off with 800 watts if you want to achieve 600 watts from a loudspeaker without any distortion stemming from the amplifier being overdriven. Best Regards,
Conanski
Old Croc Joined: 26 January 2006 Location: Ottawa, Canada Status: Offline Points: 2544 |
The thing about speakers and amps is that regardless what final combination you come up with you need to leave some unused headroom in both. Everybody knows that overdriving amplifiers is bad but fewer realize that pushing a speaker right to it's rated limit is just as bad. IMO if you want some durability from the gear you should "writeoff" the last 3db of potential output the speakers can generate on paper, because in practice it's probably gong to be soaked up by power compression anyway.. which is heating of the voice coil that raises impedance and decreases output. Driving a speaker into power compression repeatedly and for long periods of time is a roulette game, it's pushing the speaker right to the edge of destruction and it's only a matter of time before they give up the ghost.
Ideally you want an amp that can deliver the peak rating of the speakers but you want to limit it to something less than that depending upon the application, for live sound target the program rating and for DJs target the continuous rating. That means you need amps with built-in adjustable limiters or you want an external processor with adjustable limiters. Edited by Conanski - 08 March 2013 at 4:42pm |
Grubbah
Thankyou! This was the answer i was looking for. Thanks to everyone else input too! |
jngggggggg
Registered User Joined: 27 April 2017 Status: Offline Points: 88 |
a bit of revival on this one but can anyone explain WHY there is a separate standard for when to spec a amp for program vs rms based on sound? (ie above, Conanski states to use rms for djs and program for live).
my context is bass music (dj) and live vocals. according to my sound reinforcement handbook (G.Davis / R.Jones) i am supposed to use program..
gen0me
Live music does not use mastering. Not in the studio meaning ofc.
jngggggggg
But as stated above, for mastered music with some live vocals, it would still be preferred to power each speaker with more than RMS to allow for Headroom on the amp if budget allows correct? Or is it just simply not necessary? Maybe I'm just overcomplicating things
