Matching stacks, different drivers |
Cheekybox
Registered User Joined: 04 October 2014 Location: Smoke Status: Offline Points: 104 |
Posted: 17 January 2018 at 4:43pm |
So if I have two stacks, 2 cubo 18 subs per side, but the drivers are different on one side to the other, how much will this impact the sound?
Is this something to not worry about too much or will it be noticeable? I will try to power them on the same amp - inf8mk2 i hope. Cheers!
Cheekybox
Ok for a more clear example....
4 hd15s, 2 per side. 2 fane colossus 15xb one side, 2 RCF 15 the other side.
Conanski
Old Croc Joined: 26 January 2006 Location: Ottawa, Canada Status: Offline Points: 2537 |
Thanks(1)
After EQ and level matching you won't be able to hear a difference. You do have EQ right?
Cheekybox
We have a db-mark xca28
To be clear, we can adjust the eq as a single sound, rather than individually? Many thanks for your response.
Conanski
Thanks(1)
Not sure what you mean by "single sound". |
Cheekybox
Together, not one at a time.
Thanks!
Conanski
Thanks(1)
You will need to EQ the L stack a little differently than the R stack.
