Matrix STR3000 schematic and help |
solscott99 ![]() New Member ![]() ![]() Joined: 15 September 2020 Location: Bristol Status: Offline Points: 4 |
![]() ![]() ![]() ![]() ![]() Posted: 15 September 2020 at 3:48pm |
Hey I am new hear so excuse me if this topic has already been covered. Im currently in the process of trying to repair my Matrix STR3000 and am unable to find a schematic online. If anyone has a PDF downloaded that would be much appreciated. The amp itself blew a couple nights ago and on further inspection there seems to be two Transistors which are visibly damaged
simonp1100 ![]() Young Croc ![]() ![]() Joined: 01 September 2008 Location: Bristol Status: Offline Points: 1049 |
If it's one channel that has blown up you could just get the transistor ID off the other channel.
I pretty sure there are no circuits for the STR3000 online but the only other option is to contact Andy from Matrix. ![]() |
There are two transistors that are visibly burnt out. Ive been trying to figure out if that is all the damage. Does anyone know of how i would go around testing them?
monkeypuzzle ![]() Young Croc ![]() Joined: 25 January 2005 Status: Offline Points: 819 |
Please don’t take this the wrong way, people here are pretty good with offering help but if you need to know how to test a transistor on a power amp with pretty high internal voltages then it might be best you give it to someone else to look at. You will need to desolder them from the board and check for current flow between the base and emitter and the base and collector and a short between collector and emitter. You will need a multimeter with diode test function on it.
Although it is possible that these are the only thing that has popped in it, it’s most likely to have been caused by or caused damage further back up the circuit. However, I have one on its way to me at some point that has dc on an output so if you do find one I’d love to know. A call to matrix is your best bet though.
M4trix ![]() Registered User ![]() ![]() Joined: 23 June 2009 Location: Croatia Status: Offline Points: 410 |
I'm here but unfortunately I don't have the schematics.
Sonic the hedge ![]() Registered User ![]() Joined: 12 May 2020 Status: Offline Points: 146 |
A couple of tips Since output transistors are bolted to heatsink, instead of removing from PCB I isolate the transistors to test in-situ by disconnecting surrounding components e.g. emitter resistors etc. These can be desoldered at one end only and left 'flying', that way nothing gets lost or forgotten where it goes Some amplifiers it's possible to test whole bank of output transistors in one go, by isolating as above and comparing the test result with a known good bank e.g. on the other (working) channel. If you find a bank that's well out then proceed to test each transistor individually to find the bad ones. Laziness can be useful at times
![]() Edited by Sonic the hedge - 16 September 2020 at 11:10pm |
kedwardsleisure ![]() Old Croc ![]() Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 4670 |
if the transistors are visibly burnt, then without stating the obvious, there's no point testing them. They're broken.
If you're talking about the output mosfets then you need to make sure none of the others are faulty including running into gate current. |
North Staffordshire |
Thanks you for this advice. Ill give it a go soon
EmPro ![]() Registered User ![]() ![]() Joined: 26 June 2020 Status: Offline Points: 183 |
Guys....you're speaking of emitter resistors,collector,base,emitter etc etc on a dual die lateral mosfet amplifier....it is not a BJT amplifier is a Mosfet,and quite easy one to fix if you have enaugh money for the outputs
![]() ![]() Edited by EmPro - 02 June 2022 at 10:38pm |
EmPro Audio
