  New Posts New Posts RSS Feed - Max length of 2/4/6mm speakons?
SamV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SamV Quote  Post ReplyReply Direct Link To This Post Topic: Max length of 2/4/6mm speakons?
    Posted: 17 August 2017 at 5:51pm
What would you say is the max usable lenths of 2/4/6mm core speakons before it becomes an issue for either sub or tops.
Like if you had to cover 60m would you rather use a local amp, or distribute amps and use XLR?
Edited by SamV - 17 August 2017 at 5:53pm
spongebob View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote spongebob Quote  Post ReplyReply Direct Link To This Post Posted: 17 August 2017 at 6:02pm
https://forum.speakerplans.com/speaker-cable-diameter_topic91454_post918757.html#918757
Would use a remote amp for 60M unless you were powering a makita site radio or similar output
Edited by spongebob - 17 August 2017 at 6:04pm
Post Options Post Options   Thanks (1) Thanks(1)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 17 August 2017 at 7:24pm
Really?
That link shows that on 4mm cable, at 30m, you've lost 3% of the power output.
How about this, some actual maths – an SH96 (not exactly a power shy box) on a 50m line, off an X4:
Can you hear a quarter of a decibel drop?
Edited by toastyghost - 17 August 2017 at 7:26pm
