  New Posts New Posts RSS Feed - MC2 1250 vs 2 * QSC 3602
Djdarch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Djdarch Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2023 at 8:14pm
Im sure the cx series and the PLX series are the same , only the CX is install specific and then the PLX is the touring version .
The "02" version of the PLX is the original ? Im sure its just refers to 3602 3600 watts at 2 ohm .
the "04" were made to put the power in at 4 ohms but couldn't handle 2 ohm loads .PLX 1804  1800 watts at 4 ohm ( 900 per channel).
That's my take on it .
as per the OP initial question, like others have said suck it and see , especially seeing as you already own the amps .
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2023 at 8:46pm
You are right there, but it is the later grey plx, that people don't rate.
In my experience, the CX are much more sturdy.
Was thinking of getting PLX1602, for home hifi, as they are cheap and Class AB iirc.
yodominic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote yodominic Quote  Post ReplyReply Direct Link To This Post Posted: 23 January 2023 at 7:31pm
Many thanks for all your thoughts, I also have a Lab FP3400 which I believe will be better at 2 ohms compared to QSC and MC2, any thoughts on this
This page was generated in 2.468 seconds.
