MC2 E45 amp ability to power 2 ohm circuit |
Page <1 234 |
Author | ||||||
cravings ![]() Old Croc ![]() ![]() Joined: 30 January 2007 Location: Ireland Status: Offline Points: 7372 |
anyone in your circles had a go of the delta 120 yet?
paulus ![]() Old Croc ![]() ![]() Joined: 14 December 2005 Location: SOUTH BIRMINGHA Status: Offline Points: 3126 |
is a shame about the e90 as it sounds great , but seeing it sat in clip on just 2 ,4 ohm drivers a channel on a 32 amp feed as well was an eye opener , many times too on 3 different systems also , using PD 1852,turbomax 1200 and turbomax red eye :( i wanted one as well
TRENDSETTER SOUND SYSTEM
levyte357- ![]() Old Croc ![]() ![]() Joined: 27 July 2012 Location: UK, South East Status: Offline Points: 7957 |
Seen it do that, on Proper 32A power, powering just 2x PD1850 8 ohm per side !! Maybe for HPF above 55hz, it would have faired better.. |
luton_soundman ![]() Old Croc ![]() ![]() Joined: 03 August 2010 Location: Bedfordshire Status: Offline Points: 4436 |
Been told theres a new amplifier coming out soon from MC2 as the e90s been discontinued.
al_x ![]() Young Croc ![]() Joined: 12 February 2006 Status: Offline Points: 826 |
It’s worth asking as I can see it being overlooked but no, we followed the correct procedure.
Elliot Thompson ![]() Old Croc ![]() ![]() Joined: 02 April 2004 Location: United States Status: Offline Points: 5069 |
That applies to all amplifiers. The load plays a factor. 4 ohms Bridged Mono: 2 ohms per channel Stereo Mode Enjoy your CVR 3302 Best Regards,
Seems in the UK, Admark AD42, is more respected, than the CVR. Friend has few Admarks, says he will never touch CVRs.
I see more CVR in use globally than any others. Preference plays a factor. The differential in output is not noticeable enough between the AD 42 and, K 35/30. However, it would make sense to buy the AD 42 for it is supposed to offer more current on demand than the K 35/30.
Best Regards,
Maybe we should continue this in another thread, as this one is about that great "mid tops" amp, the MC2 E45..
Sounds good.
Best Regards,
Page <1 234 |
