MC2 E45 amp ability to power 2 ohm circuit |
Post Reply | Page <1 234 |
Author | ||||||
cravings
anyone in your circles had a go of the delta 120 yet?
paulus
Old Croc Joined: 14 December 2005 Location: SOUTH BIRMINGHA Status: Offline Points: 3181 |
is a shame about the e90 as it sounds great , but seeing it sat in clip on just 2 ,4 ohm drivers a channel on a 32 amp feed as well was an eye opener , many times too on 3 different systems also , using PD 1852,turbomax 1200 and turbomax red eye :( i wanted one as well
TRENDSETTER SOUND SYSTEM
levyte357-
Seen it do that, on Proper 32A power, powering just 2x PD1850 8 ohm per side !! Maybe for HPF above 55hz, it would have faired better.. |
luton_soundman
Old Croc Joined: 03 August 2010 Location: Bedfordshire Status: Offline Points: 4538 |
Been told theres a new amplifier coming out soon from MC2 as the e90s been discontinued.
al_x
Young Croc Joined: 12 February 2006 Status: Offline Points: 834 |
It’s worth asking as I can see it being overlooked but no, we followed the correct procedure.
Old Croc Joined: 02 April 2004 Location: United States Status: Offline Points: 5172 |
That applies to all amplifiers. The load plays a factor. 4 ohms Bridged Mono: 2 ohms per channel Stereo Mode Enjoy your CVR 3302 Best Regards,
levyte357-
Seems in the UK, Admark AD42, is more respected, than the CVR. Friend has few Admarks, says he will never touch CVRs.
I see more CVR in use globally than any others. Preference plays a factor. The differential in output is not noticeable enough between the AD 42 and, K 35/30. However, it would make sense to buy the AD 42 for it is supposed to offer more current on demand than the K 35/30.
Best Regards,
levyte357-
Maybe we should continue this in another thread, as this one is about that great "mid tops" amp, the MC2 E45..
Sounds good.
Best Regards,
