mc2 e90 |
Post Reply | Page <123 |
Author | |||
MarjanM
Thing is that some boxes can actually take that power no problem. As a mater of fact it will probably be okeyish power for our BA218 that are 7200W programe power at 4 ohms. So i am always in a holly grail search for an amp that can drive two boxes per channel. The new PKN XE10000-U is just right size for one box per channel. K20 is ok for 2 ohm but probably on boxes with smaller power handling.
teknojay
Registered User Joined: 08 November 2006 Location: Peterborough Status: Offline Points: 415 |
I use a plm10000q @ 4Ω on my 4 pd186 loaded boke thl828 copies and can't recommend it enough absolutely beautiful sounding amp and PLENTY of power
levyte357-
Will be very difficult for someone to upgrade from PL9.
Unless money to spend on K20, or 2x amps to drive 4x subs each. Think I'd prefer the 2x amp route. |
MarjanM
10000q can not deliver the power they claim when 4 channels driven on sub duty.
levyte357-
I guess some of these "big" lightweight amps on sub will do rated power, if HPF is approx 60hz, which doesn't really demand much current, and great for pop, etc.. However HPF 40-50hz, soon separates the wheat from the chaff, some of even the most expensive lightweights just won't tolerate that at 2 ohms - 2.66 ohms. With some of the Labsub/21" BPH crew, even driving cabs with 35hz HPF. |
teknojay
I'm more than happy with the noise mine puts out with hpf set at 40hz :)
Ras Loud
Young Croc Joined: 08 January 2012 Status: Offline Points: 754 |
Just use two E90's.
csg
[QUOTE
I guess some of these "big" lightweight amps on sub will do rated power, if HPF is approx 60hz, which doesn't really demand much current, and great for pop, etc.. However HPF 40-50hz, soon separates the wheat from the chaff, some of even the most expensive lightweights just won't tolerate that at 2 ohms - 2.66 ohms. With some of the Labsub/21" BPH crew, even driving cabs with 35hz HPF. [/QUOTE] Ray - it may interest you to know that i HPF my subs at 28Hz, never any higher...one PLM14K drives 8 of my single 18" subs to the edge of their existence with ease, even in the mid - low 30's.
shagnasty
"Sell PL 9.0 to buy mc2???"
More like sell Mc2 to buy pl 9.0!!! Unless sub offends you!!!!
levyte357-
mi mong
Registered User Joined: 23 February 2010 Location: im here Status: Offline Points: 108 |
looks like I will be keeping the pl9.0's for a while! some real good comments about the e90 and lightweight amps in general. I cant afford two e90 amps and the k20 is quite expensive and I would have to run at 2ohm( I believe this is frowned upon for all amps) I will have look at the matrix and the pkn6000 they might be an option for me
i went out today in my dressing gown......
csg
the pkn6000 is well worth having a look at, excellent amps. Personally i am not keen on the sound of the matrix amps on sub, they sound too dry to me. I am far from convinced on their reliability too.
As for 2 ohm operaton, whilst it is perfectly true that all amps are equal in terms of damping factor versus load impedance, the top tier of amplifiers ( for me, powersoft, QSC PL3 series, Lab gruppen, Hollstern) cope with 2 ohm impedance's with total ease and reliability. Thermal loads on these amps at 2Ω operation are no issue, indeed most are thermally and electrically stable into 1Ω loads... but from a sound quality perspective it is a personal thing - my view is that with a low tuned sub, 4 ohm pr 8 ohm loads with give you a tighter, more articulate sound, but with well damped or over damped tight sounding subs, 2 ohm operation can give the sub a warmer sound.
