measured:lab 13000 vs proline 3000 |
Post Reply | Page 123 7> |
airbell
Registered User Joined: 11 June 2009 Location: Berlin, Germany Status: Offline Points: 284 |
Posted: 29 December 2011 at 7:58pm |
Hello,
i wanted to share some interesting measurements a colleague and me did yesterday. we used a konstantan-wire to simulate 2x4ohm resistors. it keeps pretty well its resistance constant even at high temperatures, and we cooled it with oil. we measured only sinus, coz we are sure the lab does its 13000watt burst, also the pc the oscilloscope was connected with was too slow to follow. we measured 30hz, 50hz, 1khz and 16khz. results for 50hz were proline: 2x1850watt sinus @ 4ohm lab gruppen: 2x1764watt sinus @ 4ohm (after ~1second) now the interesting part: power consumption: proline 3000: 5000watt, 6500VA lab gruppen 13000: 4000watt, 6000VA peaks of power consumption were higher, but we measured just before clipping. at the end the fuse of the proline came and the power switch at the front panel has broken. even if both amps had limiters, it was possible to get a very unnice looking curve without hitting the input level too high. this measurements are no 100%precise laboratory results, but we tried hard to get as good results as possible. now i was wondering a lot about the power consumption... if you caltulate with the effective power (watts) it all makes sense, the proline has a good efficience of 2x1850watt / 5000watt =0,74 =74% and the lab gruppen 2x1764watt / 4000watt =0,882 = 88,2%. but actually, if you consider how much you can get out of an 16a fuse or a generator, you have always to calculate with the appearing power (VA). VA of both amps was almost the same. and thats what suprised me a lot. no question the lab gruppen wins in generel, less weight, more peak power, so will do actually in any case louder than the proline, but if its about powerconsumption in VA they are almost the same for the same output, and i would have never expect that. best regards Edited by airbell - 29 December 2011 at 8:57pm |
andyamp
Old Croc Joined: 21 July 2007 Location: United Kingdom Status: Offline Points: 2115 |
how did you test the power consumption?
http://www.matrixamplification.com/ |
airbell
the guy i did the test with had a device for it.
we put it directly before 230V ac input of the amps. if you want to know which exactly i have to ask him for the brand and type again, but it is a pretty good one! only thing i may add is that the voltage dropped down to 217V during the test. Edited by airbell - 29 December 2011 at 9:44pm |
levyte357
The 10,000 Points Club Joined: 10 May 2004 Location: UK, London Status: Offline Points: 11743 |
Why do you say that? The LabG spec says 4400wpc @ 4 ohm stereo. I'd be pretty p*ssed off if my sub amp on bench could only muster approx 1800W per channel, as opposed to published spec of approx 4kwpc @ 4 ohms. But then, I suppose many "lie weight" manufacturers are doing this very thing... |
MarjanM
How did you measured the output? Did you just took the output voltage and then used the 4 ohm load to calculate it?
csg
With respect, this is starting to sound like a stuck record. As everybody knows, the lab gruppen is designed to deliver high dynamic peaks of power, as is required for any music programme containing any kind of dynamic range even highly compressed forms of music ( drum and bass etc) tend to have a dynamic range of 6db, which is more than adequate for the lab to deliver its published specs I realise that your requirements for power are somewhat more demanding than is the norm, however you must realise that large manufacturers like lab have to build amps designed to work optimally in their target market - in this case the pro end of the touring and installation market. Unfortunately, the roots / sound system sector is not where they are aiming this kind of amplifier. with the aim of "putting my money where my mouth is" however, being a long term lab user myself, and quite happy in my belief that labs can play bass as well as anything else i have ever used, im happy to offer a fully lab loaded drive rack to any sound system who wants to try it out, we me in attendance of course.
levyte357
I was really talking in comparison to something like QSC PL9, or PL6.0. Both rapidly gaining reputation for doing what they say on the tin, even with 3-4 PD1850s per channel. The old stigma about lightweights not being able to do roots sub, is now more about needing lighweight rated approx 1.5x -2x equivalent torroidial for 4 ohm load. Edited by levyte357 - 30 December 2011 at 12:23pm |
paulus
Old Croc Joined: 14 December 2005 Location: SOUTH BIRMINGHA Status: Offline Points: 3181 |
Never heard the real lab,but the.copy 13000 I heard had 3 x fane 1500s a side and delivered without clipping and is 750 delivered
Inc shipping and import.duty!!!!yes it may pop but may be worth the risk!! |
TRENDSETTER SOUND SYSTEM
levyte357
<Off Topic>, I'm sure Fane 1500s would also sound nice in my protos.. |
paulus
Any pics of these beauts lev,?'
airbell
yes thats what we did. we took the rms voltage ² divided by the resistance. we also checked the resistance directly after measuring to check if the heat doesnt affect it. "even highly compressed forms of music ( drum and bass etc) tend to
deliver its published specs" sorry but that is not true. you are right that even heavy drum and bass has a little dynamic range, but for some tracks its almost nothing.the difference between a sine and some drum n bass tracks is almost nothing. i wrote that the lab is better because its obviously.thats why a second hand lab is still several times more expensive than a brand new tamp 3000. i think for 95%of the applications the high peak power of the lab gruppen makes really sense. i tested only 1 lab gruppen for my 16x ciare 12sw horn loaded subs (which are similar to a half eaw bh760) and it was unbelievable how much the amp pushed the speakers while playing some nice rock and pop tracks. but as soon as i played some nice drum n bass tracks the PAL turned it down, was still pretty nice but i noticed that the speakers could have take a lot more. even with electro in generell or every track where you have a "longer" bassdrum the amp couldnt deliver its rated output, but something in between. i think the measurements were correct, as its written on lab specs that the PAL limits the output power down not to hit the 16a circuit breaker. actually its all about what you want to do, if you do touring with rock and pop bands, or techno, i think the lab gruppen is perfect. if you have 16speakers like me you take 2 of them, each on an own 16a circuit, and on the third you put your mid/high amps and maybe the mixing pult. if you do often drum and bass and dubstep, or want to build a big soundystem for a huge cinema, i would take several tamp3000s coz actually this amp is really underrated. dont forget that the peak power of the tamp is also higher than the sine, no question its not as much as the lab gruppen Edited by airbell - 30 December 2011 at 1:54pm |
Smiter
Registered User Joined: 21 August 2010 Location: UK Status: Offline Points: 1160 |
I'd say for the cost of one of those labs, you could buy quite a few of the prolines!
