  New Posts New Posts RSS Feed - melted drivers out what for new??
lorenzo14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lorenzo14 Quote  Post ReplyReply Direct Link To This Post Topic: melted drivers out what for new??
    Posted: 13 January 2009 at 4:03am
ok this is my thoughts...
So i got my double reflex 15" Jamo made bins that need new drivers...
got a 3 way system with some active peaveys doing my mid around 500watts.
they hold up, but not enough bass b4 from the old 700w cabs
was looking at these as replacement drivers??
Eminence kilomax 15 (mabye bit too big!??)
Eminence Kappa 15
the pricey route???
PD 156
or
PDN.15SB4 (magnet looks small doh?? or are these perfect?)
want these cabs to be able to handle all my bass needs at the moment inc. some good dub sub but eventually act as kick bins in a bigger system with some 18' scoops maybe (love those bull-x  mykey.. (in future).
kinda don't mind shelling out if its worth it sound/power wise..
Replys well appreciated!Star
other info if it helps
bins are about 600mm in depth and width not sure of litre size??
probably gonna power em with two mono bridged amps, as i gave the amcron bakCry
budget for amp and 4xdrivers bout £800max ish?
Edited by lorenzo14 - 13 January 2009 at 4:17am
Post Options Post Options   Thanks (0) Thanks(0)   Quote lorenzo14 Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2009 at 4:20am
Was looking on the Blue Aran website as reference but anywhere cheaper, want to get new.
Edited by lorenzo14 - 13 January 2009 at 4:21am
boycey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boycey Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2009 at 10:33am
if you are going to stick with the jamo cabs get a rough idea of volume (W-18mm x H-18mm x D-18mm) and measure the ports. you can then put this into winisd and simulate response with various drivers, not perfect but better than guessing in the dark. oh and kilomax are apparently rubbish- won't take their rated power.
the only thing more dangerous than a person who doesn't give a f**k is a person who gives a sh*t.
djscooby View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djscooby Quote  Post ReplyReply Direct Link To This Post Posted: 18 February 2009 at 3:14pm
If you are putting them in bass bins then i suggest that you put kappa15"lf
http://bluearan.com/index.php?id=EMIKAP15LFA&product=Eminence_Kappa_15LF&browsemode=category
cheap as chips good low end for bins your laughin with them in em
Well my wife has kicked me out saying it's over due to my obsession with speakers don't know watt I'm gonna do with no ohm to go to
knet94 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote knet94 Quote  Post ReplyReply Direct Link To This Post Posted: 16 June 2009 at 10:17pm
If you're willing to spend £95 on new Eminence Kappa Pros why not look for some used PD 1550's. Someone was selling some for £100 each not too long back.
SamV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SamV Quote  Post ReplyReply Direct Link To This Post Posted: 16 June 2009 at 11:22pm
You can get Fane XBs for around that price, excellent drivers.
Tony Wilkes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Wilkes Quote  Post ReplyReply Direct Link To This Post Posted: 17 June 2009 at 9:11am
Either Kappa LF  or Kappalite 3015LF will offer probably the best bang for your money.Check the cab suitability first of course.
Tony
Post Options Post Options   Thanks (0) Thanks(0)   Quote lorenzo14 Quote  Post ReplyReply Direct Link To This Post Posted: 18 June 2009 at 3:56pm
I put in Kappa's not LF but they sound alrite as subs, fart a bit when i tryed to use em as kik bins not a good idea, does that mean the box is too big?? cool for the moment doh was thinking of building USB's or HD's butwhaaatis the difference? will them drivers hold out or should i try and swap them for LF's??
If anyone wants 4 burnt out Jamo drivers for FREE (bout 350watts) PM me with details i'm based in north London, don't wanna chuck em recycle anyone.
++++Wots the easiest way to work out litre size with the minimal amount of mathmatics??
Invention is 93% perspiration...
Post Options Post Options   Thanks (0) Thanks(0)   Quote boycey Quote  Post ReplyReply Direct Link To This Post Posted: 19 June 2009 at 11:42am
measure height, width, depth in millimetres- multiply- divide by a million. voila!
