  New Posts New Posts RSS Feed - Messed up insert holes!
mrcheggman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mrcheggman Quote  Post ReplyReply Direct Link To This Post Topic: Messed up insert holes!
    Posted: 18 January 2019 at 1:35pm
Hi
So I was attempting to insert wood inserts for the first time and to be honest, we've made a bit of a mess of it and two of the holes don't line up. Is there any harm in just rotating the driver, drilling new holes and filling in the ne ones? It seems like it would be okay but this is pretty much my only option. TIA
Edited by mrcheggman - 18 February 2019 at 6:19pm
JonB67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JonB67 Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2019 at 2:44pm
either that or plug the errant holes with a woodglue and sawdust mix (pva type... not polyurethane obviously) and let it set and redrill. Get the mix right and it goes as hard as hell.
Both will work fine
JulianDA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JulianDA Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2019 at 2:53pm
Another easy fix is to drill a bigger hole, glue in a dowel pin, sand it flush and then drill the correct hole through that.
