MHB 4818 Simulation |
Page 12> |
jaya000 ![]() Registered User ![]() Joined: 24 August 2008 Location: India Status: Offline Points: 59 |
![]() ![]() ![]() ![]() ![]() Posted: 16 September 2012 at 6:30am |
![]() I want guidance for hornresp input. I have done but i think i need some guidance specially for ATC. Please tell me if my hornresp inputs are correct or not? So i need guidance from experts ![]() |
_djk_ ![]() Old Croc ![]() Joined: 23 November 2004 Location: United States Status: Offline Points: 6002 |
A MHB 4818 is a box, what is the driver?
djk
Thanks DJK. The driver is Chinese made. I have tested it for thiel-small parameters with LMS. Fs : 34.86 Qms : 21.68 Qes Z: 0.32 Qts : 0.318 Vas : 171.86 Re : 5.0 ohm Sd. 1195 Mmd : 222.24 Lerc 3.41 Cms 84.75 Spl 95.4 BL : 28.9 This is with 4 layer voice coil. Any mistakes? |
Peter Jan ![]() Young Croc ![]() ![]() Joined: 16 December 2008 Location: Belgium Status: Offline Points: 1010 |
Looking at the figures and if they are correct (seems okay with the sensitiviy figure not exagerated), it seems like a decent low driver that may have an Xmax of around 8mm or something. But what respons are you after ? Do you have these 4818 already made and look for a suitable driver or do you have drivers and look for a cabinet to put them in or is everything at this point just a start from scratch ?
That looks like a very good driver for the MHB 4818 (Keele W-bin).
djk
I have the driver. So looking for the cabinet. In my country W bin is quite popular, hence was checking the same for driver i have. Thanks djk, you are always helpful. My hornresp input is ok?
Atc looks about right, depending on what you considder as being the compression chamber and the throat or the onset of the horn, but I can't see Vtc being 30 liter, that should be less. |
Thanks Peter Jan,
I calculated the area marked as Vtc. The calculation is as under 42.07 width till horn starts 10.6 height 57.4 depth of the box. so it calculated as 42.07 x 10.6 x 57.4 = 25597 + added speaker volume 4403. So i rounded as 30000. The triangle volume i adjusted towards round cutout of plywood . ![]() |
The baffle is roughly 33cm x 33cm or ~1100cm² where the horn begin, so S1=1140 as you put it in, was a good starting point. It's a bit hard to determin where the the compression chamber truelly ends and the horn begins, but it's certainly not much more than the volume the speaker cone encloses up to the mounting baffle or a bit more than that 4,4 liter.
geraelec2 ![]() New Member ![]() Joined: 02 July 2015 Status: Offline Points: 1 |
Hi. I loved all the tips and information given in this post, thanks to everyone. In other business, is there any chance to get the image with a better resolution? Please, thanks in advance. |
sn95 ![]() Registered User ![]() Joined: 10 March 2013 Location: USA Status: Offline Points: 351 |
YES free speaker plans or free horn plans
mhtplsh ![]() Registered User ![]() Joined: 27 August 2007 Status: Offline Points: 112 |
Sorry sn95. i saw it today so posting today. uploads/2632/MHB_4818_LIKE_W_BIN_box.pdf |
Page 12> |
