Microscooper drivers/amps |
djpix99
Topic: Microscooper drivers/ampsPosted: 07 October 2007 at 4:59pm |
I currently have a pair of Stapiers 15" microscoopers made by insomnia loaded with PDN.15SB40 drivers(600watts 8ohms) and they get run off either a Crest LT2000 or Yamaha P7000s.
I find them to be quite good be I feel they could be a little better, could I improve them by changing drivers or amps?
tommysb
Joined: 24 April 2006 Location: Finland Status: Offline Points: 1036 |
Posted: 07 October 2007 at 11:52pm |
I have some Matrix UKP 1300 we could test them with if you'd like?
CHAMPION
Joined: 30 September 2004 Location: United Kingdom Status: Offline Points: 3667 |
Posted: 08 October 2007 at 10:23am |
Iv put PD156 or PD1550 in these cabs, im tempetd to use the 18-sound 15MB700 (103db)
or the B&C
Again the Fane Xb is a very good driver foe this cab.
The Neo driver your using wont sond as good as the ones i have listed. On the negative side you will need bigger amp power !
Positive side, they will sound awsome !
Sticks n Stones
Mark James
Joined: 15 January 2006 Location: rig side Status: Offline Points: 5306 |
Posted: 08 October 2007 at 10:57am |
the problem is [but thisis a guese/opinion]
i think another pair in a stack [so 4 coupled] might make a helluva difference horns seem to be like that lol try with another pair it might make a huge difference |
insert silly sentence here
lglauberman
Joined: 28 December 2006 Location: United States Status: Offline Points: 15 |
Posted: 10 October 2007 at 11:38pm |
4 makes a big difference. I have 2 scoops per side, loaded with B&C 15PS100 with QSC PLX3602 for power and all is well.
AlfieDring
Joined: 04 September 2006 Location: Bath, UK Status: Offline Points: 842 |
Posted: 28 February 2008 at 2:36am |
Whats the frequency response like on these microscoops?
Have to choose between two of these and two vintage jbl style 15" scoops. They will be used in a bedroom and for houseparties and stuff until more are made :) Do these drop as low as a JBL 4530? Also hows the transient response / can they deliver a nice solid kick? Heres the competition.... http://www.dancetech.com/aa_dt_new/pa/15-scoop.cfm Cheers. |
