Mid range/ 12” box suggestions |
ednew88
Registered User Joined: 29 August 2012 Status: Offline Points: 224 |
Posted: 08 August 2018 at 7:06am |
helping a mate to build a 4 way roots sound system.. usual set up scoops/upper bass/ mids with c/d on tops.
Stuck with the mid range- looking for suggestions for a box/driver combo which can handle somewhere around 180hz up to the compression driver nicely. C/d is likely to be the bms 4544 so can be crossed fairly low if needed. Looking for something that’s going to sound warm and rounded.
Is 12” the way to go and what box designs should we be looking at? Thoughts and discussion appreciated! |
RoadRunnersDust
Young Croc Joined: 03 December 2013 Location: United Kingdom Status: Offline Points: 561 |
from 180 upwards you could also consider a 10” mid that should allow you more option for crossing to the CD?
JonB67
someone on here relatively recently designed a nice looking reflex top based on a 12 inch bms driver. I think that they posted plans too although i may be wrong. Have a search!
