  New Posts New Posts RSS Feed - Mid range/ 12” box suggestions
ednew88 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ednew88 Quote  Post ReplyReply Direct Link To This Post Topic: Mid range/ 12” box suggestions
    Posted: 08 August 2018 at 7:06am
helping a mate to build a 4 way roots sound system.. usual set up scoops/upper bass/ mids with c/d on tops.
Stuck with the mid range- looking for suggestions for a box/driver combo which can handle somewhere around 180hz up to the compression driver nicely. C/d  is likely to be the bms 4544 so can be crossed fairly low if needed. Looking for something that’s going to sound warm and rounded.
Is 12” the way to go and what box designs should we be looking at?
Thoughts and discussion appreciated!
Post Options Post Options   Thanks (0) Thanks(0)   Quote RoadRunnersDust Quote  Post ReplyReply Direct Link To This Post Posted: 11 August 2018 at 4:01pm
from 180 upwards you could also consider a 10” mid that should allow you more option for crossing to the CD?
Buying myself a TFL-760H... piece by piece >.<
JonB67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JonB67 Quote  Post ReplyReply Direct Link To This Post Posted: 12 August 2018 at 4:38am
someone on here relatively recently designed a nice looking reflex top based on a 12 inch bms driver. I think that they posted plans too although i may be wrong. Have  a search!
