Mid Top recommendations to sit above Cubos |
Post Reply | Page 12> |
Author | |||
IainB
Registered User Joined: 25 November 2016 Location: Rushden Status: Offline Points: 422 |
Posted: 07 December 2017 at 9:35pm |
Current setup is Cubo 15s, Cubo 18s (in build) and Cubo kicks - 6 boxes in total.
Im using a pair of JBL SF25s for my mid tops, but want something smaller and more suitable. Ideal stack height would be 180/200cms and a footprint of 60x60cms to match the Cubos would be great. Only doing small events at the minute, so dont need massive throw, outside events will be based out of a 6x12m marquee. I was thinking something MT* based, but not sure if that will be overkill for my current requirements?
charlysays
Registered User Joined: 16 June 2015 Location: Wales Status: Offline Points: 413 |
I'm running cubo subs and used JBL SF25s for a long time with them. Their compression driver is appaling but with a truck load of sub from the cubos it was sort of pleasing mainly just due to my eyeballs rattling with sub.
I picked up some JBL MP415 tops. Many consider these to be low end too but the CD is massive upgrade and runs smoothly up to 20khz. The difference when doing an AB test between the SF25 and MP415 is night and day. MP415 is only 350w rms but is loud. They're quite compact and light. I like them. |
SouthwestCNC
How about some orbit 4’s?
rosssss224
Registered User Joined: 25 July 2012 Status: Offline Points: 447 |
Edited by rosssss224 - 08 December 2017 at 9:10am |
rosssss224
we have some MT 101' s and they work great
IainB
It was your thread about sub placement that made me post this its something that's been worrying me (running the JBLs) and I thought it was about time that I sorted the mid/top end out
Good choice, but ideally want to home build (I actually enjoy it!)
Your system is part of the reason for going the Cubo route will look into the MT101s |
rosssss224
good stuff! We're actually in the process of upgrading to super bass horns but wll be sad to see the cubes go! Keeping the kicks though and will probably keep the subs
concept-10
Young Croc Joined: 17 May 2016 Status: Offline Points: 1293 |
You will need kick bins if you go the MT rout, Cubo kick 15 is an excellent bin, with the right driver they sound very nice but you will be running 3/4 way active going this rout, dual 15 + 2" comp in the right cab can sound very good above Cubo's, 3 way active or 2 way with a well thought out passive x'over to the comp driver.
IainB
Cubos are a nice size for me at the minute, If I go bigger im going to need more storage, have the garage racked and everything has a space at the minute (just!). Have you got a link to the plans you used for the MTs at all please?
Kicks were the first speakers I ever built bought the 15s and building the 18s (then whichever top I go for). Everything is running off my VSX26 at the minute... but very valid point, im currently 3 way and will need to go 4 (not a problem if I run mono)
Edited by IainB - 08 December 2017 at 12:53pm |
rosssss224
We didnt build them actually. Saw them for sale for £160 so couldn't say no!
charlysays
I'll be very interested in what you build. I fancy building some mid tops but don't really fancy using the extra DSP bands and amp channels to avoid the whole passive crossover nightmare. Just looked up plans for MT 101 and can only find MT 130? Tbh, I still don't see what the issue is with the JBL MP400 series tops- they're a massive upgrade over the JRX and their response plot looks remarkbly flat all the way up to 20khz. Before I bought them I did a lot of searching and couldn't find anyone with a bad word to say about them with some preferring them over the SRX. Also that paragraph from Rog Mogale says that you want something like an extra 10db under 100hz for dance music (hence the cubos) and a dip in the mid range- if you have a flat response system peoples heads get cut off by the mids in his words, before they can feel any bass. I dunno, im starting to wonder if my idea of what sounds and feels good is not what "is" good lol Edited by charlysays - 09 December 2017 at 6:10pm |
cravings
mt101 are just a single 10" version of the mt102 on the main speakerplans site.
