Mid/Top Speaker |
Jack1991
Registered User Joined: 05 February 2020 Location: Bristol Status: Offline Points: 491 |
Posted: 11 February 2020 at 12:47pm |
Looking to build a 2 way mid/top speaker to go with my tham12 sub.
I have been looking at the 8" Fane Sovreign Mid and the Eminence Apt150vt Tweeter. With a 3.5k crossover and a Lpad to bring the tweeter db down to match the Fane Mid. Specs: Fane 225rms 95db Eminence 45rms 105db Any advice on what cab/box to use? The specs for the fane says enclosure size which i can work out how to m ake a box that size. But do you think the size specified would be before the driver is fitted? Also how do i go about it as i want to fit the tweeter in same box.
Edited by Jack1991 - 11 February 2020 at 2:03pm |
djeddie
Would've thought it would mean volume of the box without any space taken by the driver, the ports, any bracing etc. The HF unit will go in the same box, it doesn't need it's own cavity, just a hole.
