Mid tops for 2x Cubo 12 + Cubo kick |
Post Reply | Page 12> |
shashnatiq
Registered User Joined: 20 December 2020 Status: Offline Points: 29 |
Posted: 20 December 2020 at 12:14pm |
Hey guys me and a friend of mine have finally decided to start our first build.
I realize the plans referenced (Cubo 12 and cubo kick) are from another website but we looked through them all and these looked like what we wanted. Also the drivers for them are cheap and readily available in our country (Bulgaria). We could not find however any midtop plans that we could pair with them either here or on the other forum. We thought about MT121s or MT130s but they both seem to be way too big and powerful for the rest of what we are planning to build. We are going to be using this system for smal parties and do not plan expanding it in the near future. In total it would be 4 Cubo 12s, 2 Cubo kicks and 2 Midtops that we have not decided on yet. Any advice is welcome. |
Conanski
I think the X10 would be sufficient.
Chris Grimshaw
Registered User Joined: 10 September 2018 Location: Sheffield Status: Offline Points: 281 |
I'm not sure I understand the need for kicks over 12" "subs". I'd be looking at ported 18"s which will likely go an octave lower. Chris
Quality sound from Sheffield
www.grimshawaudio.com |
bob4
Old Croc Joined: 29 February 2004 Location: Finland/Germany Status: Offline Points: 1842 |
Weird plan for a system. It really depends a lot, we don't know how much experience and knowledge you have, the reason for your current plan, etc. Cubo 12 has a big design compromise. It sacrifices low frequency output to obtain compact box size and high output. It struggles to reproduce any bass under 45 hz. It also has a huge boost in the kick range above 140 hz which needs to be eq:d down. I struggle to see any use for the cubo12, except for specific donk/tek/wtf music genres that lack real bass and subbass, or in special applications like 12V/off the grid. It doesnt make much sense to have cubo 12 as a "subwoofer", and then have another, different "kick bin". options: 1. Just build 6 x cubo 12 as a one-way bass solution (if you reaaally want cubo) 2. Choose a different sub design, use cubo12 or cubo kick as kick if you must 3. Build something entirely different (probably the best option) |
shashnatiq
We are also considering building the following
(for each side) 2x Cubo 15 Cubo Kick 15 mt121 Would this be a lot better? The reason we wanted the Cubo 12s is because we would use them mainly for house parties with ~50 people at most, we don't own a truck or any other way to transport them besides our cars, and we are also both students so money is an issue. The music they will be used for is techno and drum and bass exclusively. We do not have any previous experience. I also estimated the cost and it looks to me as though the drivers will only be ~25% cheaper for the 12s, we would have to spend a lot less on amplifiers. Also on the other forum Cubo said the Cubo 15 will take 600 watts to power. The eminence driver is rated at 600. My understanding is limited but I always thought the power handling numbers on driver or amps (at least the cheaper ones) are massively over stated. I realize this is probably bottom tier, please understand that the financial situation we are in is not that great, bu would a behringer KM1700 amplifier be sufficient to power 2 Eminence Kappa pro 15s (used in the Cubo 15)? My main concern with not going the 15 inch route is powering the speakers on the tight budget with have. Edited by shashnatiq - 21 December 2020 at 4:51pm |
shashnatiq
We are also open to building anything else of course, if the budget remains the same and the drivers are available at thomann.
Earplug
For small "house parties", just build some cubo 15's - with a couple of 12" & 1"/1,4" reflex above. You could start with just 2 of each, then expand as needed. And why do you want kick bins for such a small/basic system. I'd say that you were overcomplicating the thing. |
shashnatiq
Thanks for the input.
What would be the best budget amplifier to power 2 of the Cubo 15s? Would the one I mentioned in my previous post (Behringer KM1700) be sufficient? Also if budget is one of our main concerns should we get a "Behringer DCX2496 Ultradrive Pro" or a simpler crossover like the "Behringer CX3400 Crossover"?
Regarding the kick bins It was just that after reading through the forums I was left with the impression that for the type of music we play it would be quite an enhancement, but perhaps I am wrong. Also Cubo says that 1 Cubo 15 kick will be a nice addition to 2 of his subs (in the plans page for the kickbin) |
Earplug
If you can afford it - get the DCX. A universe above the other (cheap) Behringer xovers. And, ok - maybe go for a Cubo 12 for kick then. I'd say that a 15 would be a bit OTT for what you are doing - as well as wasted! Keep the 15's for the sub. |
shashnatiq
Thanks for the info everyone!
bob4
This might be of interest to you........
KaphaSound
Registered User Joined: 22 July 2020 Status: Offline Points: 102 |
50hz really isn’t very low, you’ll feel like you’re missing some 2/3rds of an octave in the sub range. I’d second the thread above and maybe recommend looking into a tham15 to push you closer to 40hz (lowest note on a standard tuned 4 string bass guitar). Cost difference in wood should be marginal and I don’t think the weight should be much more either although it will be a larger box.
Edited by KaphaSound - 22 December 2020 at 5:41am |
