Mids and highs to go with HD15’s |
Page <12 |
Morison
Joined: 05 November 2004 Location: United Kingdom Status: Offline Points: 20 |
Posted: 02 December 2004 at 4:49pm |
Sorry for the double post, here's what it should have been.
Errr, no. Most Flashlight systems use Flashlights. Otherwise, they wouldn't be Flashlight systems ;-) (Flashlight was Turbo's previous flagship array system, w horn loaded 12, 6.5 and 1 drivers set up for narrow dispersion (25*20degrees, IIRC)) THL2s aren't the same as an 811 with an added bass section either - the THL2 has a 6.5" mid, while the 811 has a 10". The 811 has 55*40 dispersion, the THL2 has 90*40. The box you're probably thinking of (811-type mid-high components + added bass) is the THL4.3, and it's a horn loaded 18 under the 10 mid. Hopefully, that might deconfuse Matieo a wee bit. Cheers, David. |
owentec
Joined: 03 November 2004 Status: Offline Points: 295 |
Posted: 02 December 2004 at 10:19pm |
Sorry... ignore me, I obviously hadn't woken up properly this morning! 1) I meant to say Hilight, not Flashlight. Oops So, making a complete U-turn, I think they will work well with HD15's. Should make a really scaleable lightweight rig. You should probably try for yourself before you buy though. Sorry again for adding confusion, Owen |
matt andrews
Joined: 15 September 2004 Status: Offline Points: 501 |
Posted: 03 December 2004 at 1:32pm |
All sounds good, will try to play with some THL811's
Matt |
miniphil
Joined: 07 July 2004 Location: United Kingdom Status: Offline Points: 71 |
Posted: 03 December 2004 at 4:02pm |
I'm aware of what it says on Turbo's specs, but I have also experimented with said speakers. While the 811 will go down to 180Hz, it sounds arse and will only throw the sound a few metres. Better to filter it out and use something in between |
Page <12 |
