  New Posts New Posts RSS Feed - Mikeys punisher special - first blast in anger!
xlogic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote xlogic Quote  Post ReplyReply Direct Link To This Post Topic: Mikeys punisher special - first blast in anger!
    Posted: 12 February 2008 at 4:40pm
Well it works! Its not died, did a blind listening test with mikey loaded box and the ciare loaded box. Was quite hard to tell any difference. If there was any i'd say the ciare gave an ever so slightly rawer sound whereas mikeys sounded cleaner. The difference was negligable.
Unfortunatley dont have any actual test equipment but if anyone around manchester has then get in touch and we can use a more scientific approach. We have another 3 gigs this weekend on Wednesday, friday and Saturday so we'll see how it holds out.
Will keep you all updated and if anyone fancys having a listen we are at Glass Bar fallowfield on wednesdat night and Jabez Clegg Friday and saturday (and the next tuesday) all in Manchester
mykey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2008 at 5:08am
Ta very much Xlogic
login4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote login4 Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2008 at 9:59pm
might have to be a little more careful with it maybe as its 400watts opposed to 1000
i was just thinking that just in case it got linked in with some ciare loaded ones
CELTIC SUBSONIC SOUND SYSTEMS
Strange Daze View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Strange Daze Quote  Post ReplyReply Direct Link To This Post Posted: 14 February 2008 at 4:36pm
what test equipment you need Dom,
I may be able to help.....bring down the SPL meter to Jabez on Saturday??
C
ps- glad the build went well....I may be tapping you for some of these soon .......hehe.,,,,
SAFETY SAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SAFETY SAM Quote  Post ReplyReply Direct Link To This Post Posted: 14 February 2008 at 5:26pm
if these drivers actually go through and some get built, would they work in the mk1's without buggering?
please say yesAngryTongue
justamadman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote justamadman Quote  Post ReplyReply Direct Link To This Post Posted: 14 February 2008 at 6:44pm
can't get rid sam???
http://www.speakerplans.com/forum/forum_posts.asp?TID=14632
in front of the bass bins baby
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 14 February 2008 at 9:53pm
C
Make it Friday, there's going to be 12 Punishers in one building
Post Options Post Options   Thanks (0) Thanks(0)   Quote SAFETY SAM Quote  Post ReplyReply Direct Link To This Post Posted: 14 February 2008 at 10:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote justamadman Quote  Post ReplyReply Direct Link To This Post Posted: 14 February 2008 at 10:10pm
Originally posted by SAFETY SAM SAFETY SAM wrote:
if that was intended for me sam, what i mean is,,,,, u were deffo sellin them a couple of weeks ago and now your asking after driversConfusedConfusedConfusedConfusedConfused
Ian
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2008 at 4:56am
i have never seen the mk1, got a pic? whats the diff?
smaller chamber?
Post Options Post Options   Thanks (0) Thanks(0)   Quote justamadman Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2008 at 11:12am
yep smaller chamber. cant really tell the difference by looking at a picture.
the new punisher design came about purely due to the new driver.
the 2005 drivers tend to burn out relatively quickly due to the size of the chamber.
limiting them right seems to stop them overheating.
Hows the new bins sam???
Contour View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Contour Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2008 at 1:41pm
Yes that is correct,
Ciare changed the basket on the 12.00SW driver to allow for better cooling. But this change made the total driver about 2cm deeper so there was not enough room behind the magnet vent in de MKI design. The MKII solved this problem. The performance of MKI and MKII are virtually the same.
Best regards,
Walt
